I’m trying to re-setup mikrotik on Check-MK 2.4.0p21 after check-mk and os upgrade - without success.
What I did so far:
- backed up check-mk instance (2.2.0p47)
- removed site and checkmk
- upgraded os to ubuntu 24.04
- installed checkmk 2.2.0p47 and restored site
- Uninstalled mikrotik Plugin with mkp and removed the rules.
- Upgraded the Check-MK instance from 2.2.0p47 to 2.3.0pxxx to 2.4.0p21.
- Downloaded Plugin 3.2.2. from checkmk-exchange, installed it via mkp and enabled it.
I expect to see an entry “Mikrotik RouterOS” at Setup → Agents → Other Integrations. But there’s no Mikrotik Entry.
$ mkp list | grep mikrotik
mikrotik 3.2.2 Mikrotik Andrea Fadda (a.fadda....) 2.3.0 - 28 Enabled (active on this site)
OMD[ck2]:~/x/mikrotik$ omd sites
SITE VERSION COMMENTS
ck2 2.4.0p21.cre default version
ChatGPT leaded the way. The Plugin is not (yet) fully compatible with Check-MK 2.4.
It has two registration functions. But only one is allowed!
So within the instance, there are these two files:
OMD[ck2]:~$ find . -type f | grep mikrotik|grep .py| grep -i wato
./local/share/check_mk/web/plugins/wato/mikrotik.py
./local/share/check_mk/web/plugins/wato/mikrotik_register.py
I like to have the main sensors and so I’m disabling mikrotik.py:
OMD[ck2]:~$ mv ./local/share/check_mk/web/plugins/wato/mikrotik.py ./local/share/check_mk/web/plugins/wato/mikrotik.py.disabled
OMD[ck2]:~$ omd restart
OMD[ck2]:~$ cmk -vv web reload
Now the Entry “Mikrotik RouterOS” is appearing at Setup → Agents → Other Integrations
And not to forget: Thank you Andrea Fadda for this plugin! It’s really useful to me!
