I encountered a change in our new Checkmk 2.2.0p21 after migrating from Checkmk 1.6.0p30. Previously, I had parameters for Dell EMC ECS storage services such as ‘EMC ECS disk load’, ‘EMC ECS disk iops’, ‘EMC Isilon Insight IQ: Number of files in the directory’, and ‘EMC ECS Temperature values of components’ under ‘Parameters for discovered services’. However, these parameters are not present in the new version.
Therefore, I need to find a way to add these missed parameters to ensure that the local checks function as expected.
This sounds like the mentioned checks are from a external mkp package installed.
If the parameters (GUI extensions) where working with 1.6, then it is normal that these are not working with 2.2.
I would first check the extensions installed.
Thanks Andreas for your replay. Actually, the parameters where working with 1.6, so How can I add an external mkp package for DELL EMC ECS to 2.2
I think you had in your 1.6 CMK an external mkp installed or some own created checks and parameter files.
First you need to take a look at your “~/local/share/check_mk/” folder structure and identify all the files that belong to the Dell EMC ECS checks.
You should also look at “~/var/log/web.log” for some error messages.
These error messages need to be fixed.
