CMK version:
check_mk 2 OS version:
Ubuntu 20.04 Error message:
none Output of “cmk --debug -vvn hostname”: (If it is a problem with checks or plugins)
Problem is the function “get_age_human_readable” is not anymore in check_mk 2.0. I cant find the method in the new API. Can someone give me the content of the method or the new version for it in check_mk 2.0?
So it would help me if you only give me the function/method content, what the method does. Then I would copy it 1:1 in a new method with the same name. (if it not would work, then pls give me a another solution)
The easy solution is - the function is not gone. If you take a look at the checks like “acme_certifcates” or “veeam_client” you see the usage of “get_age_human_readable”. This is for classic legacy checks.
If you want to use this function inside a new CMK 2 check you need to make an import at the start.
from cmk.base.check_api import (
get_age_human_readable,
Thanks that was the solution for my problem
If I may ask you one more question, is there a guide for a migration to cmk 2.0?
I have simmilar issues with WATO checks, like “ListofStrings” is also not anymore in check_mk 2.0. Can I also import that from a lib or is there a diffrent approach nessecary?
