Missing monitoring data for check plugins
CMK version: 2.0.0p19
Server OS: Rocky Linux 8.5
Agent OS: Linux
Error message: [Check_MK] Missing monitoring data for check plugins: chrony, kernel_performance, kernel_util, local, logins, postfix_mailq, postfix_mailq_status
Check_MK WARN
Check_MK Agent UNKNOWN
Check_MK Discovery UNKNOWN
Checkmk version 2.0.0p19
Trying to acquire lock on /omd/sites/main/var/check_mk/license_usage/next_run
Got lock on /omd/sites/main/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/main/var/check_mk/license_usage/history.json
Got lock on /omd/sites/main/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/main/var/check_mk/license_usage/history.json
Released lock on /omd/sites/main/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/main/var/check_mk/license_usage/next_run
Released lock on /omd/sites/main/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/main/var/check_mk/autochecks/MY-HOST.mk
+ FETCHING DATA
[cpu_tracking] Start [7f09edda5b50]
Connecting via TCP to x.x.x.x:6556 (5.0s timeout)
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(base_path=PosixPath('/omd/sites/main/tmp/check_mk/cache/MY-HOST'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 65 sec, allowed is 0 sec)
Reading data from agent
Output is encrypted
Try to decrypt output
Write data to cache file /omd/sites/main/tmp/check_mk/cache/MY-HOST
Trying to acquire lock on /omd/sites/main/tmp/check_mk/cache/MY-HOST
Got lock on /omd/sites/main/tmp/check_mk/cache/MY-HOST
Releasing lock on /omd/sites/main/tmp/check_mk/cache/MY-HOST
Released lock on /omd/sites/main/tmp/check_mk/cache/MY-HOST
Closing TCP connection to x.x.x.x:6556
[cpu_tracking] Stop [7f09edda5b50 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=1.0899999998509884))]
[cpu_tracking] Start [7f09edd733d0]
Piggyback file '/omd/sites/main/tmp/check_mk/piggyback/MY-HOST/MY-VMCENTER': MY-VMCENTER
No piggyback files for 'x.x.x.x'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/main/tmp/check_mk/data_source_cache/piggyback/MY-HOST'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7f09edd733d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f09edda5cd0]
+ PARSE FETCHER RESULTS
Trying to acquire lock on /omd/sites/main/var/check_mk/persisted/MY-HOST
Got lock on /omd/sites/main/var/check_mk/persisted/MY-HOST
Releasing lock on /omd/sites/main/var/check_mk/persisted/MY-HOST
Released lock on /omd/sites/main/var/check_mk/persisted/MY-HOST
Stored persisted sections: lnx_packages, lnx_distro, lnx_cpuinfo, dmidecode, lnx_uname, lnx_video, lnx_ip_r, lnx_sysctl
Using persisted section SectionName('lnx_packages')
Using persisted section SectionName('lnx_distro')
Using persisted section SectionName('lnx_cpuinfo')
Using persisted section SectionName('dmidecode')
Using persisted section SectionName('lnx_uname')
Using persisted section SectionName('lnx_video')
Using persisted section SectionName('lnx_ip_r')
Using persisted section SectionName('lnx_sysctl')
  -> Add sections: ['check_mk', 'cifsmounts', 'cpu', 'df', 'diskstat', 'dmidecode', 'labels', 'lnx_cpuinfo', 'lnx_distro', 'lnx_if', 'lnx_ip_r', 'lnx_packages', 'lnx_sysctl', 'lnx_uname', 'lnx_video', 'mem', 'mounts', 'nfsmounts', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'uptime']
No persisted sections loaded
  -> Add sections: ['esx_vsphere_vm', 'labels']
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/main/tmp/check_mk/counters/MY-HOST
Got lock on /omd/sites/main/tmp/check_mk/counters/MY-HOST
Releasing lock on /omd/sites/main/tmp/check_mk/counters/MY-HOST
Released lock on /omd/sites/main/tmp/check_mk/counters/MY-HOST
CPU load             15 min load: 0.56
Check_MK Agent       Item not found in monitoring data
Disk IO SUMMARY      PEND - Initializing counters
ESX Datastores       Stored on MYVMDATASTORE (8.00 TB/54.2% free)
ESX Hostsystem       Running on MYVMWARE
ESX Snapshots        Count: 0
Filesystem /         45.92% used (5.51 of 11.99 GB, warn/crit at 93.00%/97.00%), trend: +13.77 MB / 24 hours - time left until disk full: more than a year
Filesystem /boot     34.17% used (169.73 of 496.67 MB, warn/crit at 93.00%/97.00%), trend: +45.91 B / 24 hours - time left until disk full: more than a year
Filesystem /opt      24.89% used (7.46 of 29.95 GB, warn/crit at 91.14%/95.57%), trend: +1.44 MB / 24 hours - time left until disk full: more than a year
Filesystem /tmp      3.55% used (36.02 of 1014.00 MB, warn/crit at 90.00%/95.00%), trend: -847.08 kB / 24 hours
Interface eth0       [2], (up), MAC: 00:50:56:89:8B:82, Speed: 10 GBit/s, In: 631 kB/s (0.05%), Out: 10.0 kB/s (<0.01%)
Interface lo         [1], (up), MAC: 00:00:00:00:00:00, Speed: unknown, In: 31.9 B/s, Out: 31.9 B/s
Memory               Total virtual memory: 48.05% - 5.57 GB of 11.59 GB
Number of threads    Count: 328 threads, Usage: 0.53%
Systemd Service Summary Total: 122, Disabled: 16, Failed: 0
TCP Connections      Established: 32
Uptime               Up since Feb 10 2022 01:02:03, Uptime: 6 days 21 hours
+ EXECUTING INVENTORY PLUGINS
 hp_proliant_mem: skipped (no data)
 ipmi_firmware: skipped (no data)
 inventory_checkmk: skipped (no data)
 inv_cisco_vlans: skipped (no data)
 inv_esx_vsphere_hostsystem: skipped (no data)
 inv_if: ok
 inv_if: skipped (no data)
 inventory_oracle_tablespaces: skipped (no data)
 dmidecode: ok
 dmidecode: skipped (no data)
 docker_node_network: skipped (no data)
 inventory_esx_vsphere_clusters: skipped (no data)
 inventory_esx_vsphere_virtual_machines: skipped (no data)
 k8s_endpoint_info: skipped (no data)
 k8s_ingress_infos: skipped (no data)
 juniper_info: skipped (no data)
 mem: ok
 mem_used: skipped (no data)
 snmp_info: skipped (no data)
 aix_baselevel: skipped (no data)
 aix_lparstat_inventory: skipped (no data)
 aix_packages: skipped (no data)
 aix_service_packs: skipped (no data)
 allnet_ip_sensoric: skipped (no data)
 aruba_wlc_aps: skipped (no data)
 check_mk: ok
 check_mk: skipped (no data)
 checkpoint_inv_tunnels: skipped (no data)
 citrix_controller: skipped (no data)
 citrix_state: skipped (no data)
 couchbase_nodes_ports: skipped (no data)
 dell_hw_info: skipped (no data)
 docker_container_labels: skipped (no data)
 docker_container_network: skipped (no data)
 docker_container_node_name: skipped (no data)
 docker_node_images: skipped (no data)
 docker_node_info: skipped (no data)
 esx_systeminfo: skipped (no data)
 fireeye_sys_status: skipped (no data)
 fritz: skipped (no data)
 hp_proliant_da_phydrv: skipped (no data)
 hp_proliant_systeminfo: skipped (no data)
 ibm_mq_channels: skipped (no data)
 ibm_mq_managers: skipped (no data)
 ibm_mq_queues: skipped (no data)
 infoblox_osinfo: skipped (no data)
 infoblox_systeminfo: skipped (no data)
 k8s_assigned_pods: skipped (no data)
 k8s_daemon_pod_containers: skipped (no data)
 k8s_job_container: skipped (no data)
 k8s_nodes: skipped (no data)
 k8s_pod_container: skipped (no data)
 k8s_pod_info: skipped (no data)
 k8s_roles: skipped (no data)
 k8s_selector: skipped (no data)
 k8s_service_info: skipped (no data)
 lnx_block_devices: skipped (no data)
 lnx_cpuinfo: ok
 lnx_cpuinfo: skipped (no data)
 lnx_distro: ok
 lnx_distro: skipped (no data)
 lnx_if: ok
 lnx_if: skipped (no data)
 lnx_ip_r: ok
 lnx_ip_r: skipped (no data)
 lnx_packages: ok
 lnx_packages: skipped (no data)
 lnx_sysctl: ok
 lnx_sysctl: skipped (no data)
 lnx_uname: ok
 lnx_uname: skipped (no data)
 lnx_video: ok
 lnx_video: skipped (no data)
 lparstat_aix: skipped (no data)
 mssql_clusters: skipped (no data)
 mssql_versions: skipped (no data)
 netapp_api_disk: skipped (no data)
 netapp_api_info: skipped (no data)
 oracle_dataguard_stats: skipped (no data)
 oracle_instance: skipped (no data)
 oracle_performance: skipped (no data)
 oracle_recovery_area: skipped (no data)
 oracle_systemparameter: skipped (no data)
 perle_chassis: skipped (no data)
 perle_chassis_slots: skipped (no data)
 perle_psmu: skipped (no data)
 prtconf: skipped (no data)
 snmp_extended_info: skipped (no data)
 snmp_os: skipped (no data)
 snmp_quantum_storage_info: skipped (no data)
 solaris_addresses: skipped (no data)
 solaris_pkginfo: skipped (no data)
 solaris_prtdiag: skipped (no data)
 solaris_prtpicl: skipped (no data)
 solaris_psrinfo: skipped (no data)
 solaris_routes: skipped (no data)
 solaris_uname: skipped (no data)
 statgrab_net: skipped (no data)
 suseconnect: skipped (no data)
 win_bios: skipped (no data)
 win_computersystem: skipped (no data)
 win_cpuinfo: skipped (no data)
 win_disks: skipped (no data)
 win_exefiles: skipped (no data)
 win_ip_r: skipped (no data)
 win_networkadapter: skipped (no data)
 win_os: skipped (no data)
 win_reg_uninstall: skipped (no data)
 win_system: skipped (no data)
 win_video: skipped (no data)
 win_wmi_software: skipped (no data)
 win_wmi_updates: skipped (no data)
 winperf_if: skipped (no data)
[cpu_tracking] Stop [7f09edda5cd0 - Snapshot(process=posix.times_result(user=0.56, system=0.07, children_user=0.0, children_system=0.0, elapsed=0.6499999994412065))]
[agent] Version: 2.0.0p6, OS: linux, [piggyback] Valid sources: MY-VMCENTER, Missing monitoring data for check plugins: chrony, kernel_performance, kernel_util, local, logins, postfix_mailq, postfix_mailq_status(!), execution time 1.7 sec | execution_time=1.740 user_time=0.570 system_time=0.070 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=1.080
Agent output:
<<<check_mk>>>
Version: 2.0.0p6
AgentOS: linux
Hostname: MY-HOST
AgentDirectory: /etc/check_mk
DataDirectory: /var/lib/check_mk_agent
SpoolDirectory: /var/lib/check_mk_agent/spool
PluginsDirectory: /usr/lib/check_mk_agent/plugins
LocalDirectory: /usr/lib/check_mk_agent/local
OnlyFrom:
<<<labels:sep(0)>>>
{"cmk/device_type":"vm"}
<<<df>>>
tmpfs                    tmpfs     3995044       0   3995044       0% /dev/shm
tmpfs                    tmpfs     3995044   50472   3944572       2% /run
tmpfs                    tmpfs     3995044       0   3995044       0% /sys/fs/cgroup
/dev/mapper/rootvg-root  xfs      12572672 5773456   6799216      46% /
/dev/mapper/vgdata-lvopt xfs      31409168 7818468  23590700      25% /opt
/dev/sda1                xfs        508588  173804    334784      35% /boot
/dev/mapper/rootvg-tmp   xfs       1038336   37828   1000508       4% /tmp
<<<df>>>
[df_inodes_start]
tmpfs                    tmpfs   998761     1   998760    1% /dev/shm
tmpfs                    tmpfs   998761   696   998065    1% /run
tmpfs                    tmpfs   998761    16   998745    1% /sys/fs/cgroup
/dev/mapper/rootvg-root  xfs   12582912 61892 12521020    1% /
/dev/mapper/vgdata-lvopt xfs   31424512 44239 31380273    1% /opt
/dev/sda1                xfs     512000   345   511655    1% /boot
/dev/mapper/rootvg-tmp   xfs    1048576    93  1048483    1% /tmp
[df_inodes_end]
<<<systemd_units>>>
[list-unit-files]
UNIT FILE STATE
proc-sys-fs-binfmt_misc.automount static
dev-hugepages.mount static
dev-mqueue.mount static
proc-fs-nfsd.mount static
proc-sys-fs-binfmt_misc.mount static
run-vmblock\x2dfuse.mount disabled
sys-fs-fuse-connections.mount static
sys-kernel-config.mount static
sys-kernel-debug.mount static
tmp.mount disabled
var-lib-nfs-rpc_pipefs.mount static
brandbot.path enabled
systemd-ask-password-console.path static
systemd-ask-password-plymouth.path static
systemd-ask-password-wall.path static
arp-ethers.service disabled
auditd.service enabled
auth-rpcgss-module.service static
autofs.service enabled
autovt@.service enabled
blk-availability.service disabled
brandbot.service static
check-mk-agent-async.service enabled
check-mk-agent@.service static
chrony-dnssrv@.service static
chrony-wait.service disabled
chronyd.service enabled
cm13_prod.service enabled
conntrackd.service disabled
console-getty.service disabled
console-shell.service disabled
container-getty@.service static
cpupower.service disabled
crond.service enabled
dbus-org.fedoraproject.FirewallD1.service enabled
dbus-org.freedesktop.hostname1.service static
dbus-org.freedesktop.import1.service static
dbus-org.freedesktop.locale1.service static
dbus-org.freedesktop.login1.service static
dbus-org.freedesktop.machine1.service static
dbus-org.freedesktop.timedate1.service static
dbus.service static
debug-shell.service disabled
dm-event.service static
dnsmasq.service disabled
dracut-cmdline.service static
dracut-initqueue.service static
dracut-mount.service static
dracut-pre-mount.service static
dracut-pre-pivot.service static
dracut-pre-trigger.service static
dracut-pre-udev.service static
dracut-shutdown.service static
ebtables.service disabled
emergency.service static
filebeat.service enabled
firewalld.service enabled
fstrim.service static
getty@.service enabled
goferd.service enabled
gssproxy.service disabled
halt-local.service static
initrd-cleanup.service static
initrd-parse-etc.service static
initrd-switch-root.service static
initrd-udevadm-cleanup-db.service static
ip6tables.service disabled
iprdump.service disabled
iprinit.service disabled
iprupdate.service disabled
iptables.service disabled
irqbalance.service enabled
kdump.service enabled
kmod-static-nodes.service static
lvm2-lvmetad.service static
lvm2-lvmpolld.service static
lvm2-monitor.service enabled
lvm2-pvscan@.service static
messagebus.service static
microcode.service enabled
munin-asyncd.service disabled
munin-node.service enabled
NetworkManager-dispatcher.service disabled
NetworkManager-wait-online.service enabled
NetworkManager.service disabled
nfs-blkmap.service disabled
nfs-config.service static
nfs-idmap.service static
nfs-idmapd.service static
nfs-lock.service static
nfs-mountd.service static
nfs-rquotad.service disabled
nfs-secure.service static
nfs-server.service disabled
nfs-utils.service static
nfs.service disabled
nfslock.service static
nmb.service disabled
ntpdate.service disabled
oddjobd.service enabled
ol-consolebaud.service enabled
oneagent.service enabled
plymouth-halt.service disabled
plymouth-kexec.service disabled
plymouth-poweroff.service disabled
plymouth-quit-wait.service disabled
plymouth-quit.service disabled
plymouth-read-write.service disabled
plymouth-reboot.service disabled
plymouth-start.service disabled
plymouth-switch-root.service static
polkit.service static
postfix.service enabled
puppet.service enabled
pxp-agent.service disabled
qualys-cloud-agent.service enabled
quotaon.service static
rc-local.service static
rdisc.service disabled
rdma-load-modules@.service static
rdma-ndd.service static
rdma.service disabled
rescue.service static
rhel-autorelabel-mark.service enabled
rhel-autorelabel.service enabled
rhel-configure.service enabled
rhel-dmesg.service enabled
rhel-domainname.service enabled
rhel-import-state.service enabled
rhel-loadmodules.service enabled
rhel-readonly.service enabled
rhsmcertd.service enabled
rpc-gssd.service static
rpc-rquotad.service disabled
rpc-statd-notify.service static
rpc-statd.service static
rpcbind.service disabled
rpcgssd.service static
rpcidmapd.service static
rsyslog.service enabled
selinux-policy-migrate-local-changes@.service static
serial-getty@.service disabled
smb.service disabled
sshd-keygen.service static
sshd.service enabled
sshd@.service static
sssd-autofs.service indirect
sssd-ifp.service static
sssd-nss.service indirect
sssd-pac.service indirect
sssd-pam.service indirect
sssd-secrets.service indirect
sssd-ssh.service indirect
sssd-sudo.service indirect
sssd.service enabled
sysstat.service enabled
systemd-ask-password-console.service static
systemd-ask-password-plymouth.service static
systemd-ask-password-wall.service static
systemd-backlight@.service static
systemd-binfmt.service static
systemd-bootchart.service disabled
systemd-firstboot.service static
systemd-fsck-root.service static
systemd-fsck@.service static
systemd-halt.service static
systemd-hibernate-resume@.service static
systemd-hibernate.service static
systemd-hostnamed.service static
systemd-hwdb-update.service static
systemd-hybrid-sleep.service static
systemd-importd.service static
systemd-initctl.service static
systemd-journal-catalog-update.service static
systemd-journal-flush.service static
systemd-journald.service static
systemd-kexec.service static
systemd-localed.service static
systemd-logind.service static
systemd-machine-id-commit.service static
systemd-machined.service static
systemd-modules-load.service static
systemd-nspawn@.service disabled
systemd-poweroff.service static
systemd-pstore.service disabled
systemd-quotacheck.service static
systemd-random-seed.service static
systemd-readahead-collect.service enabled
systemd-readahead-done.service indirect
systemd-readahead-drop.service enabled
systemd-readahead-replay.service enabled
systemd-reboot.service static
systemd-remount-fs.service static
systemd-rfkill@.service static
systemd-shutdownd.service static
systemd-suspend.service static
systemd-sysctl.service static
systemd-timedated.service static
systemd-tmpfiles-clean.service static
systemd-tmpfiles-setup-dev.service static
systemd-tmpfiles-setup.service static
systemd-udev-settle.service static
systemd-udev-trigger.service static
systemd-udevd.service static
systemd-update-done.service static
systemd-update-utmp-runlevel.service static
systemd-update-utmp.service static
systemd-user-sessions.service static
systemd-vconsole-setup.service static
tcsd.service disabled
teamd@.service static
telegraf.service enabled
tuned.service enabled
vgauthd.service disabled
vmtoolsd.service enabled
wpa_supplicant.service disabled
-.slice static
machine.slice static
system.slice static
user.slice static
check-mk-agent.socket enabled
dbus.socket static
dm-event.socket enabled
lvm2-lvmetad.socket enabled
lvm2-lvmpolld.socket enabled
rpcbind.socket enabled
sshd.socket disabled
sssd-autofs.socket disabled
sssd-nss.socket disabled
sssd-pac.socket disabled
sssd-pam-priv.socket disabled
sssd-pam.socket disabled
sssd-secrets.socket disabled
sssd-ssh.socket disabled
sssd-sudo.socket disabled
syslog.socket static
systemd-initctl.socket static
systemd-journald.socket static
systemd-shutdownd.socket static
systemd-udevd-control.socket static
systemd-udevd-kernel.socket static
basic.target static
bluetooth.target static
cryptsetup-pre.target static
cryptsetup.target static
ctrl-alt-del.target disabled
default.target enabled
emergency.target static
final.target static
getty-pre.target static
getty.target static
graphical.target static
halt.target disabled
hibernate.target static
hybrid-sleep.target static
initrd-fs.target static
initrd-root-fs.target static
initrd-switch-root.target static
initrd.target static
iprutils.target disabled
kexec.target disabled
local-fs-pre.target static
local-fs.target static
machines.target disabled
multi-user.target enabled
network-online.target static
network-pre.target static
network.target static
nfs-client.target enabled
nss-lookup.target static
nss-user-lookup.target static
paths.target static
poweroff.target disabled
printer.target static
rdma-hw.target static
reboot.target disabled
remote-cryptsetup.target disabled
remote-fs-pre.target static
remote-fs.target enabled
rescue.target disabled
rpc_pipefs.target static
rpcbind.target static
runlevel0.target disabled
runlevel1.target disabled
runlevel2.target enabled
runlevel3.target enabled
runlevel4.target enabled
runlevel5.target static
runlevel6.target disabled
shutdown.target static
sigpwr.target static
sleep.target static
slices.target static
smartcard.target static
sockets.target static
sound.target static
suspend.target static
swap.target static
sysinit.target static
system-update.target static
time-sync.target static
timers.target static
umount.target static
chrony-dnssrv@.timer disabled
fstrim.timer disabled
systemd-readahead-done.timer indirect
systemd-tmpfiles-clean.timer static
307 unit files listed.
[all]
 UNIT LOAD ACTIVE SUB JOB
 proc-sys-fs-binfmt_misc.automount loaded active running Arbitrary Executable File Formats File System Automount Point
 dev-block-8:16.device loaded active plugged Virtual_disk
 dev-block-8:2.device loaded active plugged Virtual_disk 2
 dev-block-8:32.device loaded active plugged Virtual_disk
 dev-cdrom.device loaded active plugged VMware_Virtual_IDE_CDROM_Drive
 dev-disk-by\x2did-ata\x2dVMware_Virtual_IDE_CDROM_Drive_10000000000000000001.device loaded active plugged VMware_Virtual_IDE_CDROM_Drive
 dev-disk-by\x2did-dm\x2dname\x2drootvg\x2droot.device loaded active plugged /dev/disk/by-id/dm-name-rootvg-root
 dev-disk-by\x2did-dm\x2dname\x2drootvg\x2dtmp.device loaded active plugged /dev/disk/by-id/dm-name-rootvg-tmp
 dev-disk-by\x2did-dm\x2dname\x2dswapvg\x2dswap.device loaded active plugged /dev/disk/by-id/dm-name-swapvg-swap
 dev-disk-by\x2did-dm\x2dname\x2dvgdata\x2dlvopt.device loaded active plugged /dev/disk/by-id/dm-name-vgdata-lvopt
 dev-disk-by\x2did-dm\x2duuid\x2dLVM\x2dG6caGxDpNfLrF61ooO2Glamp4AM0qLjSdZcUeiPCoSKWu1jm5hSGcGWiUq3tNGO2.device loaded active plugged /dev/disk/by-id/dm-uuid-LVM-G6caGxDpNfLrF61ooO2Glamp4AM0qLjSdZcUeiPCoSKWu1jm5hSGcGWiUq3tNGO2
 dev-disk-by\x2did-dm\x2duuid\x2dLVM\x2dG6caGxDpNfLrF61ooO2Glamp4AM0qLjSZnv1XzjFNvq82IHi4X9vjgBj4SZXYVyc.device loaded active plugged /dev/disk/by-id/dm-uuid-LVM-G6caGxDpNfLrF61ooO2Glamp4AM0qLjSZnv1XzjFNvq82IHi4X9vjgBj4SZXYVyc
 dev-disk-by\x2did-dm\x2duuid\x2dLVM\x2dghj8YB0BCMx1bCWC0IPcKw20lvO8ZRyTrptdzAKVuJcI9Xe5MlK9jeVCS36vXfS3.device loaded active plugged /dev/disk/by-id/dm-uuid-LVM-ghj8YB0BCMx1bCWC0IPcKw20lvO8ZRyTrptdzAKVuJcI9Xe5MlK9jeVCS36vXfS3
 dev-disk-by\x2did-dm\x2duuid\x2dLVM\x2dzafVAzO236fh1Ph09QZ8o5sL3JtAMqKhVpfZqV85LTPcYulQbwJxjENClBce6Gpc.device loaded active plugged /dev/disk/by-id/dm-uuid-LVM-zafVAzO236fh1Ph09QZ8o5sL3JtAMqKhVpfZqV85LTPcYulQbwJxjENClBce6Gpc
 dev-disk-by\x2did-lvm\x2dpv\x2duuid\x2d1yoPii\x2drHOS\x2d8R30\x2dgRGW\x2dIBFp\x2dPfcY\x2dcz00be.device loaded active plugged Virtual_disk 2
 dev-disk-by\x2did-lvm\x2dpv\x2duuid\x2d31f29X\x2dVJ61\x2dtRuV\x2dfKoJ\x2d2ZOk\x2dzsq6\x2d2JIdan.device loaded active plugged Virtual_disk
 dev-disk-by\x2did-lvm\x2dpv\x2duuid\x2dOffTwe\x2dty4n\x2dRTbo\x2dTZTl\x2dSP2L\x2d5Amh\x2dX4wW2Z.device loaded active plugged Virtual_disk
 dev-disk-by\x2dpath-pci\x2d0000:00:07.1\x2data\x2d2.0.device loaded active plugged VMware_Virtual_IDE_CDROM_Drive
 dev-disk-by\x2dpath-pci\x2d0000:03:00.0\x2dscsi\x2d0:0:0:0.device loaded active plugged Virtual_disk
 dev-disk-by\x2dpath-pci\x2d0000:03:00.0\x2dscsi\x2d0:0:0:0\x2dpart1.device loaded active plugged Virtual_disk 1
 dev-disk-by\x2dpath-pci\x2d0000:03:00.0\x2dscsi\x2d0:0:0:0\x2dpart2.device loaded active plugged Virtual_disk 2
 dev-disk-by\x2dpath-pci\x2d0000:03:00.0\x2dscsi\x2d0:0:1:0.device loaded active plugged Virtual_disk
 dev-disk-by\x2dpath-pci\x2d0000:03:00.0\x2dscsi\x2d0:0:2:0.device loaded active plugged Virtual_disk
 dev-disk-by\x2duuid-5df8580d\x2d4dc6\x2d4cf4\x2db6e9\x2d8f1dfbb17aff.device loaded active plugged /dev/disk/by-uuid/5df8580d-4dc6-4cf4-b6e9-8f1dfbb17aff
 dev-disk-by\x2duuid-b09e8b79\x2d5504\x2d442d\x2dbf5f\x2d0c4d5713ddb7.device loaded active plugged /dev/disk/by-uuid/b09e8b79-5504-442d-bf5f-0c4d5713ddb7
 dev-disk-by\x2duuid-bf848a53\x2dd975\x2d41e0\x2dac95\x2d78ce096b6987.device loaded active plugged Virtual_disk 1
 dev-disk-by\x2duuid-c2b279d8\x2dc3a0\x2d4f24\x2d8fb6\x2d9aee6a0d190f.device loaded active plugged /dev/disk/by-uuid/c2b279d8-c3a0-4f24-8fb6-9aee6a0d190f
 dev-disk-by\x2duuid-fa4e5b60\x2df2d0\x2d44c1\x2db825\x2da5f325d0b536.device loaded active plugged /dev/disk/by-uuid/fa4e5b60-f2d0-44c1-b825-a5f325d0b536
 dev-dm\x2d0.device loaded active plugged /dev/dm-0
 dev-dm\x2d1.device loaded active plugged /dev/dm-1
 dev-dm\x2d2.device loaded active plugged /dev/dm-2
 dev-dm\x2d3.device loaded active plugged /dev/dm-3
 dev-mapper-rootvg\x2droot.device loaded active plugged /dev/mapper/rootvg-root
 dev-mapper-rootvg\x2dtmp.device loaded active plugged /dev/mapper/rootvg-tmp
 dev-mapper-swapvg\x2dswap.device loaded active plugged /dev/mapper/swapvg-swap
 dev-mapper-vgdata\x2dlvopt.device loaded active plugged /dev/mapper/vgdata-lvopt
 dev-rootvg-root.device loaded active plugged /dev/rootvg/root
 dev-rootvg-tmp.device loaded active plugged /dev/rootvg/tmp
 dev-sda.device loaded active plugged Virtual_disk
 dev-sda1.device loaded active plugged Virtual_disk 1
 dev-sda2.device loaded active plugged Virtual_disk 2
 dev-sdb.device loaded active plugged Virtual_disk
 dev-sdc.device loaded active plugged Virtual_disk
 dev-sr0.device loaded active plugged VMware_Virtual_IDE_CDROM_Drive
 dev-swapvg-swap.device loaded active plugged /dev/swapvg/swap
 dev-ttyS0.device loaded active plugged /dev/ttyS0
 dev-ttyS1.device loaded active plugged /dev/ttyS1
 dev-ttyS2.device loaded active plugged /dev/ttyS2
 dev-ttyS3.device loaded active plugged /dev/ttyS3
 dev-vgdata-lvopt.device loaded active plugged /dev/vgdata/lvopt
 sys-devices-pci0000:00-0000:00:07.1-ata2-host2-target2:0:0-2:0:0:0-block-sr0.device loaded active plugged VMware_Virtual_IDE_CDROM_Drive
 sys-devices-pci0000:00-0000:00:15.0-0000:03:00.0-host0-target0:0:0-0:0:0:0-block-sda-sda1.device loaded active plugged Virtual_disk 1
 sys-devices-pci0000:00-0000:00:15.0-0000:03:00.0-host0-target0:0:0-0:0:0:0-block-sda-sda2.device loaded active plugged Virtual_disk 2
 sys-devices-pci0000:00-0000:00:15.0-0000:03:00.0-host0-target0:0:0-0:0:0:0-block-sda.device loaded active plugged Virtual_disk
 sys-devices-pci0000:00-0000:00:15.0-0000:03:00.0-host0-target0:0:1-0:0:1:0-block-sdb.device loaded active plugged Virtual_disk
 sys-devices-pci0000:00-0000:00:15.0-0000:03:00.0-host0-target0:0:2-0:0:2:0-block-sdc.device loaded active plugged Virtual_disk
 sys-devices-pci0000:00-0000:00:16.0-0000:0b:00.0-net-eth0.device loaded active plugged VMXNET3 Ethernet Controller
 sys-devices-platform-serial8250-tty-ttyS0.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS0
 sys-devices-platform-serial8250-tty-ttyS1.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS1
 sys-devices-platform-serial8250-tty-ttyS2.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS2
 sys-devices-platform-serial8250-tty-ttyS3.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS3
 sys-devices-virtual-block-dm\x2d0.device loaded active plugged /sys/devices/virtual/block/dm-0
 sys-devices-virtual-block-dm\x2d1.device loaded active plugged /sys/devices/virtual/block/dm-1
 sys-devices-virtual-block-dm\x2d2.device loaded active plugged /sys/devices/virtual/block/dm-2
 sys-devices-virtual-block-dm\x2d3.device loaded active plugged /sys/devices/virtual/block/dm-3
 sys-module-configfs.device loaded active plugged /sys/module/configfs
 sys-module-fuse.device loaded active plugged /sys/module/fuse
 sys-subsystem-net-devices-eth0.device loaded active plugged VMXNET3 Ethernet Controller
 -.mount loaded active mounted /
 boot.mount loaded active mounted /boot
 dev-hugepages.mount loaded active mounted Huge Pages File System
 dev-mqueue.mount loaded active mounted POSIX Message Queue File System
 nfs-home.mount loaded active mounted /nfs/home
 opt.mount loaded active mounted /opt
 proc-fs-nfsd.mount loaded inactive dead NFSD configuration filesystem
 proc-sys-fs-binfmt_misc.mount loaded active mounted Arbitrary Executable File Formats File System
 sys-fs-fuse-connections.mount loaded active mounted FUSE Control File System
 sys-kernel-config.mount loaded active mounted Configuration File System
 sys-kernel-debug.mount loaded active mounted Debug File System
● sysroot.mount not-found inactive dead sysroot.mount
 tmp.mount loaded active mounted /tmp
 var-lib-nfs-rpc_pipefs.mount loaded active mounted RPC Pipe File System
 brandbot.path loaded active waiting Flexible branding
 systemd-ask-password-console.path loaded inactive dead Dispatch Password Requests to Console Directory Watch
 systemd-ask-password-plymouth.path loaded active waiting Forward Password Requests to Plymouth Directory Watch
 systemd-ask-password-wall.path loaded active waiting Forward Password Requests to Wall Directory Watch
 auditd.service loaded active running Security Auditing Service
 auth-rpcgss-module.service loaded inactive dead Kernel Module supporting RPCSEC_GSS
 autofs.service loaded active running Automounts filesystems on demand
 brandbot.service loaded inactive dead Flexible Branding Service
 check-mk-agent-async.service loaded inactive dead Checkmk agent - Asynchronous background tasks
● check-mk-agent@37-x.x.x.x:6556-x.x.x.x:41274.service loaded failed failed Checkmk agent (x.x.x.x:41274)
● check-mk-agent@38-x.x.x.x:6556-x.x.x.x:41398.service loaded failed failed Checkmk agent (x.x.x.x:41398)
● check-mk-agent@419-x.x.x.x:6556-x.x.x.x:57474.service loaded failed failed Checkmk agent (x.x.x.x:57474)
● check-mk-agent@465-x.x.x.x:6556-x.x.x.x:45896.service loaded failed failed Checkmk agent (x.x.x.x:45896)
● check-mk-agent@475-x.x.x.x:6556-x.x.x.x:55844.service loaded failed failed Checkmk agent (x.x.x.x:55844)
● check-mk-agent@476-x.x.x.x:6556-x.x.x.x:55872.service loaded failed failed Checkmk agent (x.x.x.x:55872)
● check-mk-agent@477-x.x.x.x:6556-x.x.x.x:55888.service loaded failed failed Checkmk agent (x.x.x.x:55888)
● check-mk-agent@478-x.x.x.x:6556-x.x.x.x:55914.service loaded failed failed Checkmk agent (x.x.x.x:55914)
● check-mk-agent@479-x.x.x.x:6556-x.x.x.x:55954.service loaded failed failed Checkmk agent (x.x.x.x:55954)
● check-mk-agent@480-x.x.x.x:6556-x.x.x.x:56024.service loaded failed failed Checkmk agent (x.x.x.x:56024)
● check-mk-agent@486-x.x.x.x:6556-x.x.x.x:42000.service loaded failed failed Checkmk agent (x.x.x.x:42000)
 check-mk-agent@491-x.x.x.x:6556-x.x.x.x:56222.service loaded activating start start Checkmk agent (x.x.x.x:56222)
● check-mk-agent@67-x.x.x.x:6556-x.x.x.x:59046.service loaded failed failed Checkmk agent (x.x.x.x:59046)
 chronyd.service loaded active running NTP client/server
● cloud-init-local.service not-found inactive dead cloud-init-local.service
 cm13_prod.service loaded active exited Akana PM - cm13_prod
 cpupower.service loaded inactive dead Configure CPU power related settings
 crond.service loaded active running Command Scheduler
 dbus.service loaded active running D-Bus System Message Bus
● display-manager.service not-found inactive dead display-manager.service
 dm-event.service loaded inactive dead Device-mapper event daemon
 dracut-cmdline.service loaded inactive dead dracut cmdline hook
 dracut-initqueue.service loaded inactive dead dracut initqueue hook
 dracut-mount.service loaded inactive dead dracut mount hook
 dracut-pre-mount.service loaded inactive dead dracut pre-mount hook
 dracut-pre-pivot.service loaded inactive dead dracut pre-pivot and cleanup hook
 dracut-pre-trigger.service loaded inactive dead dracut pre-trigger hook
 dracut-pre-udev.service loaded inactive dead dracut pre-udev hook
 dracut-shutdown.service loaded inactive dead Restore /run/initramfs
 ebtables.service loaded inactive dead Ethernet Bridge Filtering tables
 emergency.service loaded inactive dead Emergency Shell
● exim.service not-found inactive dead exim.service
 filebeat.service loaded active running Filebeat sends log files to Logstash or directly to Elasticsearch.
 firewalld.service loaded active running firewalld - dynamic firewall daemon
 getty@tty1.service loaded active running Getty on tty1
 goferd.service loaded active running Gofer Agent
 gssproxy.service loaded active running GSSAPI Proxy Daemon
 initrd-cleanup.service loaded inactive dead Cleaning Up and Shutting Down Daemons
 initrd-parse-etc.service loaded inactive dead Reload Configuration from the Real Root
 initrd-switch-root.service loaded inactive dead Switch Root
 initrd-udevadm-cleanup-db.service loaded inactive dead Cleanup udevd DB
 ip6tables.service loaded inactive dead IPv6 firewall with ip6tables
● ipset.service not-found inactive dead ipset.service
 iptables.service loaded inactive dead IPv4 firewall with iptables
 irqbalance.service loaded inactive dead irqbalance daemon
● kdump.service loaded failed failed Crash recovery kernel arming
 kmod-static-nodes.service loaded active exited Create list of required static device nodes for the current kernel
● lvm2-activation.service not-found inactive dead lvm2-activation.service
 lvm2-lvmetad.service loaded active running LVM2 metadata daemon
 lvm2-lvmpolld.service loaded inactive dead LVM2 poll daemon
 lvm2-monitor.service loaded active exited Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
 lvm2-pvscan@8:16.service loaded active exited LVM2 PV scan on device 8:16
 lvm2-pvscan@8:2.service loaded active exited LVM2 PV scan on device 8:2
 lvm2-pvscan@8:32.service loaded active exited LVM2 PV scan on device 8:32
 microcode.service loaded inactive dead Load CPU microcode update
 munin-asyncd.service loaded inactive dead Munin Node - Asynchronous Proxy
 munin-node.service loaded active running Munin Node
 network.service loaded active exited LSB: Bring up/down networking
 NetworkManager-wait-online.service loaded inactive dead Network Manager Wait Online
 NetworkManager.service loaded inactive dead Network Manager
 nfs-config.service loaded inactive dead Preprocess NFS configuration
 nfs-idmapd.service loaded inactive dead NFSv4 ID-name mapping service
 nfs-mountd.service loaded inactive dead NFS Mount Daemon
● nfs-secure-server.service not-found inactive dead nfs-secure-server.service
 nfs-server.service loaded inactive dead NFS server and services
 nfs-utils.service loaded inactive dead NFS server and client services
● ntpd.service not-found inactive dead ntpd.service
 ntpdate.service loaded inactive dead Set time via NTP
 oddjobd.service loaded active running privileged operations for unprivileged applications
 ol-consolebaud.service loaded inactive dead Check console baud rate
 oneagent.service loaded active running Dynatrace OneAgent
 plymouth-quit-wait.service loaded inactive dead Wait for Plymouth Boot Screen to Quit
 plymouth-quit.service loaded inactive dead Terminate Plymouth Boot Screen
 plymouth-read-write.service loaded inactive dead Tell Plymouth To Write Out Runtime Data
 plymouth-start.service loaded inactive dead Show Plymouth Boot Screen
 plymouth-switch-root.service loaded inactive dead Plymouth switch root service
 polkit.service loaded active running Authorization Manager
 postfix.service loaded active running Postfix Mail Transport Agent
 puppet.service loaded active running Puppet agent
 qualys-cloud-agent.service loaded active running Qualys cloud agent daemon
 rc-local.service loaded inactive dead /etc/rc.d/rc.local Compatibility
 rescue.service loaded inactive dead Rescue Shell
 rhel-autorelabel-mark.service loaded inactive dead Mark the need to relabel after reboot
 rhel-autorelabel.service loaded inactive dead Relabel all filesystems, if necessary
 rhel-configure.service loaded inactive dead Reconfigure the system on administrator request
 rhel-dmesg.service loaded active exited Dump dmesg to /var/log/dmesg
 rhel-domainname.service loaded active exited Read and set NIS domainname from /etc/sysconfig/network
 rhel-import-state.service loaded active exited Import network configuration from initramfs
 rhel-loadmodules.service loaded inactive dead Load legacy module configuration
 rhel-readonly.service loaded active exited Configure read-only root support
 rhsmcertd.service loaded active running Enable periodic update of entitlement certificates.
 rpc-gssd.service loaded active running RPC security service for NFS client and server
 rpc-statd-notify.service loaded inactive dead Notify NFS peers of a restart
 rpc-statd.service loaded active running NFS status monitor for NFSv2/3 locking.
 rpcbind.service loaded active running RPC bind service
 rsyslog.service loaded active running System Logging Service
 selinux-policy-migrate-local-changes@targeted.service loaded inactive dead Migrate local SELinux policy changes from the old store structure to the new structure
● sendmail.service not-found inactive dead sendmail.service
● sntp.service not-found inactive dead sntp.service
 sshd-keygen.service loaded inactive dead OpenSSH Server Key Generation
 sshd.service loaded active running OpenSSH server daemon
 sssd.service loaded active running System Security Services Daemon
● syslog.service not-found inactive dead syslog.service
 sysstat.service loaded active exited Resets System Activity Logs
 systemd-ask-password-console.service loaded inactive dead Dispatch Password Requests to Console
 systemd-ask-password-plymouth.service loaded inactive dead Forward Password Requests to Plymouth
 systemd-ask-password-wall.service loaded inactive dead Forward Password Requests to Wall
 systemd-binfmt.service loaded inactive dead Set Up Additional Binary Formats
 systemd-firstboot.service loaded inactive dead First Boot Wizard
 systemd-fsck-root.service loaded inactive dead File System Check on Root Device
 systemd-hwdb-update.service loaded inactive dead Rebuild Hardware Database
 systemd-initctl.service loaded inactive dead /dev/initctl Compatibility Daemon
 systemd-journal-catalog-update.service loaded inactive dead Rebuild Journal Catalog
 systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
 systemd-journald.service loaded active running Journal Service
 systemd-logind.service loaded active running Login Service
 systemd-machine-id-commit.service loaded inactive dead Commit a transient machine-id on disk
 systemd-modules-load.service loaded active exited Load Kernel Modules
 systemd-random-seed.service loaded active exited Load/Save Random Seed
 systemd-readahead-collect.service loaded inactive dead Collect Read-Ahead Data
 systemd-readahead-done.service loaded inactive dead Stop Read-Ahead Data Collection
 systemd-readahead-replay.service loaded inactive dead Replay Read-Ahead Data
 systemd-reboot.service loaded inactive dead Reboot
 systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
 systemd-shutdownd.service loaded inactive dead Delayed Shutdown Service
 systemd-sysctl.service loaded active exited Apply Kernel Variables
● systemd-sysusers.service not-found inactive dead systemd-sysusers.service
● systemd-timesyncd.service not-found inactive dead systemd-timesyncd.service
 systemd-tmpfiles-clean.service loaded inactive dead Cleanup of Temporary Directories
 systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev
 systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories
 systemd-udev-trigger.service loaded active exited udev Coldplug all Devices
 systemd-udevd.service loaded active running udev Kernel Device Manager
 systemd-update-done.service loaded inactive dead Update is Completed
 systemd-update-utmp-runlevel.service loaded inactive dead Update UTMP about System Runlevel Changes
 systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown
 systemd-user-sessions.service loaded active exited Permit User Sessions
 systemd-vconsole-setup.service loaded active exited Setup Virtual Console
 telegraf.service loaded active running The plugin-driven server agent for reporting metrics into InfluxDB
 tuned.service loaded active running Dynamic System Tuning Daemon
 vgauthd.service loaded active running VGAuth Service for open-vm-tools
 vmtoolsd.service loaded active running Service for virtual machines hosted on VMware
● ypbind.service not-found inactive dead ypbind.service
● yppasswdd.service not-found inactive dead yppasswdd.service
● ypserv.service not-found inactive dead ypserv.service
● ypxfrd.service not-found inactive dead ypxfrd.service
 -.slice loaded active active Root Slice
 system-check\x2dmk\x2dagent.slice loaded active active system-check\x2dmk\x2dagent.slice
 system-getty.slice loaded active active system-getty.slice
 system-lvm2\x2dpvscan.slice loaded active active system-lvm2\x2dpvscan.slice
 system-selinux\x2dpolicy\x2dmigrate\x2dlocal\x2dchanges.slice loaded active active system-selinux\x2dpolicy\x2dmigrate\x2dlocal\x2dchanges.slice
 system.slice loaded active active System Slice
 user.slice loaded active active User and Session Slice
 check-mk-agent.socket loaded active listening Checkmk agent socket
● check_mk.socket not-found inactive dead check_mk.socket
 dbus.socket loaded active running D-Bus System Message Bus Socket
 dm-event.socket loaded active listening Device-mapper event daemon FIFOs
 lvm2-lvmetad.socket loaded active running LVM2 metadata daemon socket
 lvm2-lvmpolld.socket loaded active listening LVM2 poll daemon socket
 rpcbind.socket loaded active running RPCbind Server Activation Socket
 sshd.socket loaded inactive dead OpenSSH Server Socket
 syslog.socket loaded inactive dead Syslog Socket
 systemd-initctl.socket loaded active listening /dev/initctl Compatibility Named Pipe
 systemd-journald.socket loaded active running Journal Socket
 systemd-shutdownd.socket loaded active listening Delayed Shutdown Socket
 systemd-udevd-control.socket loaded active running udev Control Socket
 systemd-udevd-kernel.socket loaded active running udev Kernel Socket
 dev-disk-by\x2did-dm\x2dname\x2dswapvg\x2dswap.swap loaded active active /dev/disk/by-id/dm-name-swapvg-swap
 dev-disk-by\x2did-dm\x2duuid\x2dLVM\x2dghj8YB0BCMx1bCWC0IPcKw20lvO8ZRyTrptdzAKVuJcI9Xe5MlK9jeVCS36vXfS3.swap loaded active active /dev/disk/by-id/dm-uuid-LVM-ghj8YB0BCMx1bCWC0IPcKw20lvO8ZRyTrptdzAKVuJcI9Xe5MlK9jeVCS36vXfS3
 dev-disk-by\x2duuid-b09e8b79\x2d5504\x2d442d\x2dbf5f\x2d0c4d5713ddb7.swap loaded active active /dev/disk/by-uuid/b09e8b79-5504-442d-bf5f-0c4d5713ddb7
 dev-dm\x2d1.swap loaded active active /dev/dm-1
 dev-mapper-swapvg\x2dswap.swap loaded active active /dev/mapper/swapvg-swap
 dev-swapvg-swap.swap loaded active active /dev/swapvg/swap
 basic.target loaded active active Basic System
 cryptsetup.target loaded active active Local Encrypted Volumes
 emergency.target loaded inactive dead Emergency Mode
 final.target loaded inactive dead Final Step
 getty-pre.target loaded inactive dead Login Prompts (Pre)
 getty.target loaded active active Login Prompts
 graphical.target loaded inactive dead Graphical Interface
 initrd-fs.target loaded inactive dead Initrd File Systems
 initrd-root-fs.target loaded inactive dead Initrd Root File System
 initrd-switch-root.target loaded inactive dead Switch Root
 initrd.target loaded inactive dead Initrd Default Target
 local-fs-pre.target loaded active active Local File Systems (Pre)
 local-fs.target loaded active active Local File Systems
 multi-user.target loaded active active Multi-User System
 network-online.target loaded active active Network is Online
 network-pre.target loaded active active Network (Pre)
 network.target loaded active active Network
 nfs-client.target loaded active active NFS client services
 nss-lookup.target loaded active active Host and Network Name Lookups
 nss-user-lookup.target loaded active active User and Group Name Lookups
 paths.target loaded active active Paths
 remote-fs-pre.target loaded active active Remote File Systems (Pre)
 remote-fs.target loaded active active Remote File Systems
 rescue.target loaded inactive dead Rescue Mode
 rpc_pipefs.target loaded active active rpc_pipefs.target
 rpcbind.target loaded active active RPC Port Mapper
 shutdown.target loaded inactive dead Shutdown
 slices.target loaded active active Slices
 sockets.target loaded active active Sockets
 swap.target loaded active active Swap
 sysinit.target loaded active active System Initialization
● syslog.target not-found inactive dead syslog.target
 time-sync.target loaded inactive dead System Time Synchronized
 timers.target loaded active active Timers
 umount.target loaded inactive dead Unmount All Filesystems
 systemd-readahead-done.timer loaded inactive dead Stop Read-Ahead Data Collection 10s After Completed Startup
 systemd-tmpfiles-clean.timer loaded active waiting Daily Cleanup of Temporary Directories
<<<nfsmounts>>>
/nfs/home ok 806027 329896 288977 524288
<<<cifsmounts>>>
<<<mounts>>>
/dev/mapper/rootvg-root / xfs rw,seclabel,relatime,attr2,inode64,noquota 0 0
/dev/mapper/vgdata-lvopt /opt xfs rw,seclabel,relatime,attr2,inode64,noquota 0 0
/dev/sda1 /boot xfs rw,seclabel,relatime,attr2,inode64,noquota 0 0
/dev/mapper/rootvg-tmp /tmp xfs rw,seclabel,relatime,attr2,inode64,noquota 0 0
<<<ps_lnx>>>
[header] CGROUP USER VSZ RSS TIME ELAPSED PID COMMAND
- root 89096 6652 00:04:53 6-21:24:40 1 /usr/lib/systemd/systemd --switched-root --system --deserialize 22
- root 0 0 00:00:00 6-21:24:40 2 [kthreadd]
- root 0 0 00:00:00 6-21:24:40 4 [kworker/0:0H]
- root 0 0 00:00:42 6-21:24:40 6 [ksoftirqd/0]
- root 0 0 00:00:00 6-21:24:40 7 [migration/0]
- root 0 0 00:00:00 6-21:24:40 8 [rcu_bh]
- root 0 0 00:01:02 6-21:24:40 9 [rcu_sched]
- root 0 0 00:00:00 6-21:24:40 10 [lru-add-drain]
- root 0 0 00:00:01 6-21:24:40 11 [watchdog/0]
- root 0 0 00:00:00 6-21:24:40 13 [kdevtmpfs]
- root 0 0 00:00:00 6-21:24:40 14 [netns]
- root 0 0 00:00:00 6-21:24:40 15 [khungtaskd]
- root 0 0 00:00:00 6-21:24:40 16 [writeback]
- root 0 0 00:00:00 6-21:24:40 17 [kintegrityd]
- root 0 0 00:00:00 6-21:24:40 18 [bioset]
- root 0 0 00:00:00 6-21:24:40 19 [bioset]
- root 0 0 00:00:00 6-21:24:40 20 [bioset]
- root 0 0 00:00:00 6-21:24:40 21 [kblockd]
- root 0 0 00:00:00 6-21:24:40 22 [md]
- root 0 0 00:00:00 6-21:24:40 23 [edac-poller]
- root 0 0 00:00:00 6-21:24:40 24 [watchdogd]
- root 0 0 00:00:02 6-21:24:40 30 [kswapd0]
- root 0 0 00:00:00 6-21:24:40 31 [ksmd]
- root 0 0 00:00:01 6-21:24:40 32 [khugepaged]
- root 0 0 00:00:00 6-21:24:40 33 [crypto]
- root 0 0 00:00:00 6-21:24:40 41 [kthrotld]
- root 0 0 00:00:00 6-21:24:40 43 [kmpath_rdacd]
- root 0 0 00:00:00 6-21:24:40 44 [kaluad]
- root 0 0 00:00:00 6-21:24:40 45 [kpsmoused]
- root 0 0 00:00:00 6-21:24:40 47 [ipv6_addrconf]
- root 0 0 00:00:00 6-21:24:40 60 [deferwq]
- root 0 0 00:00:00 6-21:24:40 95 [kauditd]
- root 0 0 00:00:00 6-21:24:40 266 [scsi_eh_0]
- root 0 0 00:00:00 6-21:24:40 267 [scsi_tmf_0]
- root 0 0 00:00:00 6-21:24:40 268 [vmw_pvscsi_wq_0]
- root 0 0 00:00:00 6-21:24:39 276 [ata_sff]
- root 0 0 00:00:00 6-21:24:39 278 [scsi_eh_1]
- root 0 0 00:00:00 6-21:24:39 279 [nfit]
- root 0 0 00:00:00 6-21:24:39 283 [scsi_tmf_1]
- root 0 0 00:00:00 6-21:24:39 284 [scsi_eh_2]
- root 0 0 00:00:00 6-21:24:39 285 [scsi_tmf_2]
- root 0 0 00:00:00 6-21:24:39 303 [irq/16-vmwgfx]
- root 0 0 00:00:00 6-21:24:39 304 [ttm_swap]
- root 0 0 00:00:00 6-21:24:39 414 [kdmflush]
- root 0 0 00:00:00 6-21:24:39 415 [bioset]
- root 0 0 00:00:00 6-21:24:39 424 [kdmflush]
- root 0 0 00:00:00 6-21:24:39 425 [bioset]
- root 0 0 00:00:00 6-21:24:39 438 [bioset]
- root 0 0 00:00:00 6-21:24:39 439 [xfsalloc]
- root 0 0 00:00:00 6-21:24:39 440 [xfs_mru_cache]
- root 0 0 00:00:00 6-21:24:39 441 [xfs-buf/dm-0]
- root 0 0 00:00:00 6-21:24:39 442 [xfs-data/dm-0]
- root 0 0 00:00:00 6-21:24:39 443 [xfs-conv/dm-0]
- root 0 0 00:00:00 6-21:24:39 444 [xfs-cil/dm-0]
- root 0 0 00:00:00 6-21:24:39 445 [xfs-reclaim/dm-]
- root 0 0 00:00:00 6-21:24:39 446 [xfs-log/dm-0]
- root 0 0 00:00:00 6-21:24:39 447 [xfs-eofblocks/d]
- root 0 0 00:01:05 6-21:24:39 448 [xfsaild/dm-0]
- root 0 0 00:00:30 6-21:24:38 449 [kworker/0:1H]
8:devices:/system.slice/systemd-journald.service,1:name=systemd:/system.slice/systemd-journald.service root 124444 66640 00:00:48 6-21:24:35 529 /usr/lib/systemd/systemd-journald
- root 0 0 00:00:00 6-21:24:35 551 [rpciod]
- root 0 0 00:00:00 6-21:24:35 553 [xprtiod]
8:devices:/system.slice/lvm2-lvmetad.service,1:name=systemd:/system.slice/lvm2-lvmetad.service root 351732 3420 00:00:00 6-21:24:35 555 /usr/sbin/lvmetad -f
8:devices:/system.slice/systemd-udevd.service,1:name=systemd:/system.slice/systemd-udevd.service root 75460 2004 00:00:00 6-21:24:35 573 /usr/lib/systemd/systemd-udevd
- root 0 0 00:00:00 6-21:24:33 678 [kdmflush]
- root 0 0 00:00:00 6-21:24:33 679 [bioset]
- root 0 0 00:00:00 6-21:24:33 683 [xfs-buf/sda1]
- root 0 0 00:00:00 6-21:24:33 684 [xfs-data/sda1]
- root 0 0 00:00:00 6-21:24:33 686 [xfs-conv/sda1]
- root 0 0 00:00:00 6-21:24:33 688 [xfs-cil/sda1]
- root 0 0 00:00:00 6-21:24:33 690 [xfs-reclaim/sda]
- root 0 0 00:00:00 6-21:24:33 691 [xfs-log/sda1]
- root 0 0 00:00:00 6-21:24:33 693 [xfs-eofblocks/s]
- root 0 0 00:00:00 6-21:24:33 694 [kdmflush]
- root 0 0 00:00:00 6-21:24:33 695 [bioset]
- root 0 0 00:00:00 6-21:24:33 697 [xfsaild/sda1]
- root 0 0 00:00:00 6-21:24:33 705 [xfs-buf/dm-3]
- root 0 0 00:00:00 6-21:24:33 706 [xfs-data/dm-3]
- root 0 0 00:00:00 6-21:24:33 707 [xfs-conv/dm-3]
- root 0 0 00:00:00 6-21:24:33 708 [xfs-cil/dm-3]
- root 0 0 00:00:00 6-21:24:33 709 [xfs-reclaim/dm-]
- root 0 0 00:00:00 6-21:24:33 710 [xfs-log/dm-3]
- root 0 0 00:00:00 6-21:24:33 711 [xfs-eofblocks/d]
- root 0 0 00:00:59 6-21:24:33 712 [xfsaild/dm-3]
- root 0 0 00:00:00 6-21:24:33 717 [xfs-buf/dm-2]
- root 0 0 00:00:00 6-21:24:33 718 [xfs-data/dm-2]
- root 0 0 00:00:00 6-21:24:33 719 [xfs-conv/dm-2]
- root 0 0 00:00:00 6-21:24:33 720 [xfs-cil/dm-2]
- root 0 0 00:00:00 6-21:24:33 721 [xfs-reclaim/dm-]
- root 0 0 00:00:00 6-21:24:33 722 [xfs-log/dm-2]
- root 0 0 00:00:00 6-21:24:33 723 [xfs-eofblocks/d]
- root 0 0 00:01:08 6-21:24:33 724 [xfsaild/dm-2]
8:devices:/system.slice/auditd.service,1:name=systemd:/system.slice/auditd.service root 58692 844 00:00:01 6-21:24:32 748 /sbin/auditd
8:devices:/system.slice/dbus.service,1:name=systemd:/system.slice/dbus.service dbus 82508 2348 00:00:21 6-21:24:31 770 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
8:devices:/system.slice/rpcbind.service,1:name=systemd:/system.slice/rpcbind.service rpc 71380 1020 00:00:00 6-21:24:31 771 /sbin/rpcbind -w
8:devices:/system.slice/vgauthd.service,1:name=systemd:/system.slice/vgauthd.service root 172772 2584 00:00:00 6-21:24:31 775 /usr/bin/VGAuthService -s
8:devices:/system.slice/vmtoolsd.service,1:name=systemd:/system.slice/vmtoolsd.service root 289372 4064 00:07:54 6-21:24:31 776 /usr/bin/vmtoolsd
8:devices:/system.slice/polkit.service,1:name=systemd:/system.slice/polkit.service polkitd 629028 6232 00:00:10 6-21:24:31 778 /usr/lib/polkit-1/polkitd --no-debug
8:devices:/system.slice/sssd.service,1:name=systemd:/system.slice/sssd.service root 293556 3636 00:00:00 6-21:24:31 782 /usr/sbin/sssd -i --logger=files
8:devices:/system.slice/gssproxy.service,1:name=systemd:/system.slice/gssproxy.service root 273756 928 00:00:00 6-21:24:31 791 /usr/sbin/gssproxy -D
8:devices:/system.slice/rpc-gssd.service,1:name=systemd:/system.slice/rpc-gssd.service root 45616 1104 00:00:00 6-21:24:31 799 /usr/sbin/rpc.gssd
8:devices:/system.slice/firewalld.service,1:name=systemd:/system.slice/firewalld.service root 367724 29788 00:02:29 6-21:24:31 809 /usr/bin/python2 -Es /usr/sbin/firewalld --nofork --nopid
8:devices:/system.slice/sssd.service,1:name=systemd:/system.slice/sssd.service root 409484 49904 00:07:15 6-21:24:31 810 /usr/libexec/sssd/sssd_be --domain default --uid 0 --gid 0 --logger=files
8:devices:/system.slice/sssd.service,1:name=systemd:/system.slice/sssd.service root 301740 10424 00:00:03 6-21:24:30 811 /usr/libexec/sssd/sssd_nss --uid 0 --gid 0 --logger=files
8:devices:/system.slice/sssd.service,1:name=systemd:/system.slice/sssd.service root 280280 4544 00:00:03 6-21:24:30 812 /usr/libexec/sssd/sssd_pam --uid 0 --gid 0 --logger=files
8:devices:/system.slice/sssd.service,1:name=systemd:/system.slice/sssd.service root 281772 4912 00:00:03 6-21:24:30 813 /usr/libexec/sssd/sssd_ssh --uid 0 --gid 0 --logger=files
8:devices:/system.slice/systemd-logind.service,1:name=systemd:/system.slice/systemd-logind.service root 40248 1992 00:00:08 6-21:24:30 815 /usr/lib/systemd/systemd-logind
8:devices:/system.slice/crond.service,1:name=systemd:/system.slice/crond.service root 131016 1964 00:00:05 6-21:24:30 827 /usr/sbin/crond -n
8:devices:/system.slice/chronyd.service,1:name=systemd:/system.slice/chronyd.service chrony 120972 1940 00:00:01 6-21:24:30 829 /usr/sbin/chronyd
8:devices:/system.slice/system-getty.slice,1:name=systemd:/system.slice/system-getty.slice/getty@tty1.service root 114832 1120 00:00:00 6-21:24:30 834 /sbin/agetty --noclear tty1 linux
8:devices:/system.slice/goferd.service,1:name=systemd:/system.slice/goferd.service root 362196 11372 00:00:06 6-21:24:24 1316 /usr/bin/python /usr/bin/goferd --foreground
8:devices:/system.slice/telegraf.service,1:name=systemd:/system.slice/telegraf.service telegraf 5739044 56796 02:04:32 6-21:24:24 1318 /usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d
8:devices:/system.slice/tuned.service,1:name=systemd:/system.slice/tuned.service root 578912 16572 00:00:48 6-21:24:24 1320 /usr/bin/python2 -Es /usr/sbin/tuned -l -P
8:devices:/system.slice/puppet.service,1:name=systemd:/system.slice/puppet.service root 340124 56312 00:00:20 6-21:24:24 1321 /opt/puppetlabs/puppet/bin/ruby /opt/puppetlabs/puppet/bin/puppet agent --no-daemonize
8:devices:/system.slice/sshd.service,1:name=systemd:/system.slice/sshd.service root 115112 3232 00:00:00 6-21:24:24 1322 /usr/sbin/sshd -D
8:devices:/system.slice/oddjobd.service,1:name=systemd:/system.slice/oddjobd.service root 55864 2164 00:00:00 6-21:24:24 1323 /usr/sbin/oddjobd -n -p /var/run/oddjobd.pid -t 300
8:devices:/system.slice/rhsmcertd.service,1:name=systemd:/system.slice/rhsmcertd.service root 120432 744 00:00:00 6-21:24:24 1328 /usr/bin/rhsmcertd
8:devices:/system.slice/munin-node.service,1:name=systemd:/system.slice/munin-node.service root 160656 10112 00:00:22 6-21:24:24 1329 /usr/bin/perl -wT /usr/sbin/munin-node --foreground
8:devices:/system.slice/filebeat.service,1:name=systemd:/system.slice/filebeat.service root 1031212 64704 00:02:18 6-21:24:24 1332 /usr/share/filebeat/bin/filebeat --environment systemd -c /etc/filebeat/filebeat.yml --path.home /usr/share/filebeat --path.config /etc/filebeat --path.data /var/lib/filebeat --path.logs /var/log/filebeat
8:devices:/system.slice/rsyslog.service,1:name=systemd:/system.slice/rsyslog.service root 530580 46664 00:00:53 6-21:24:23 1334 /usr/sbin/rsyslogd -n
8:devices:/system.slice/rpc-statd.service,1:name=systemd:/system.slice/rpc-statd.service rpcuser 47684 1988 00:00:00 6-21:24:23 1339 /usr/sbin/rpc.statd
8:devices:/system.slice/autofs.service,1:name=systemd:/system.slice/autofs.service root 510044 4844 00:00:27 6-21:24:23 1368 /usr/sbin/automount --systemd-service --dont-check-daemon
8:devices:/system.slice/cm13_prod.service,1:name=systemd:/system.slice/cm13_prod.service apigw 117916 1808 00:00:00 6-21:24:23 1370 /bin/sh /opt/akana_sw/pm/bin/startup.sh cm13_prod -fork
8:devices:/system.slice/cm13_prod.service,1:name=systemd:/system.slice/cm13_prod.service apigw 6800432 5007892 13:44:00 6-21:24:23 1393 /opt/akana_sw/pm/jre/bin/java -Xmx4096M -Dlog4j2.formatMsgNoLookups=true -classpath /opt/akana_sw/pm/instances/cm13_prod:/opt/akana_sw/pm/lib/felix.jar -Djava.awt.headless=true -Dlog4j.configuration=file:/opt/akana_sw/pm/config/log4j-startup.properties -Dsoa.root.dir=/opt/akana_sw/pm -Dfelix.cache.rootdir=/opt/akana_sw/pm/instances/cm13_prod -Dfelix.config.properties=file:/opt/akana_sw/pm/instances/cm13_prod/config.properties -Dfelix.system.properties=file:/opt/akana_sw/pm/instances/cm13_prod/system.properties -Dorg.osgi.framework.storage=cache org.apache.felix.main.Main
8:devices:/system.slice/postfix.service,1:name=systemd:/system.slice/postfix.service root 95888 2584 00:00:03 6-21:24:21 1641 /usr/libexec/postfix/master -w
8:devices:/system.slice/postfix.service,1:name=systemd:/system.slice/postfix.service postfix 106836 4448 00:00:01 6-21:24:21 1705 qmgr -l -t unix -u
- root 0 0 00:00:00 6-21:24:15 1830 [nfsiod]
- root 0 0 00:00:00 28:30 6236 [kworker/0:4]
- root 0 0 00:00:00 20:29 8062 [kworker/0:1]
- root 0 0 00:00:00 16:41 8760 [kworker/u256:1]
8:devices:/system.slice/postfix.service,1:name=systemd:/system.slice/postfix.service postfix 106724 4676 00:00:00 15:37 9048 pickup -l -t unix -u
- root 0 0 00:00:00 12:27 9618 [kworker/0:3]
- root 0 0 00:00:00 07:27 10440 [kworker/0:0]
- root 0 0 00:00:00 04:26 10848 [kworker/0:2]
8:devices:/system.slice/system-check\x2dmk\x2dagent.slice,1:name=systemd:/system.slice/system-check\x2dmk\x2dagent.slice/check-mk-agent@491-x.x.x.x:6556-x.x.x.x:56222.service root 118268 2392 00:00:00 00:01 11746 /bin/bash /usr/bin/check_mk_agent
8:devices:/system.slice/system-check\x2dmk\x2dagent.slice,1:name=systemd:/system.slice/system-check\x2dmk\x2dagent.slice/check-mk-agent@491-x.x.x.x:6556-x.x.x.x:56222.service root 117872 820 00:00:00 00:01 11762 /bin/bash /usr/bin/check_mk_agent
8:devices:/system.slice/system-check\x2dmk\x2dagent.slice,1:name=systemd:/system.slice/system-check\x2dmk\x2dagent.slice/check-mk-agent@491-x.x.x.x:6556-x.x.x.x:56222.service root 42132 2924 00:00:00 00:01 11765 openssl enc -aes-256-cbc -md sha256 -k -nosalt
8:devices:/system.slice/system-check\x2dmk\x2dagent.slice,1:name=systemd:/system.slice/system-check\x2dmk\x2dagent.slice/check-mk-agent@491-x.x.x.x:6556-x.x.x.x:56222.service root 118268 1128 00:00:00 00:00 11791 /bin/bash /usr/bin/check_mk_agent
8:devices:/system.slice/system-check\x2dmk\x2dagent.slice,1:name=systemd:/system.slice/system-check\x2dmk\x2dagent.slice/check-mk-agent@491-x.x.x.x:6556-x.x.x.x:56222.service root 160032 2228 00:00:00 00:00 11792 ps ax -o cgroup:512,user:32,vsz,rss,cputime,etime,pid,command --columns 10000
8:devices:/system.slice/system-check\x2dmk\x2dagent.slice,1:name=systemd:/system.slice/system-check\x2dmk\x2dagent.slice/check-mk-agent@491-x.x.x.x:6556-x.x.x.x:56222.service root 112664 888 00:00:00 00:00 11793 tr -s
- root 0 0 00:00:00 08:25:41 30047 [kworker/u256:0]
8:devices:/system.slice/qualys-cloud-agent.service,1:name=systemd:/system.slice/qualys-cloud-agent.service root 320156 17284 00:00:19 6-10:49:26 84717 /usr/local/qualys/cloud-agent/bin/qualys-cloud-agent
8:devices:/system.slice/oneagent.service,1:name=systemd:/system.slice/oneagent.service root 397532 1788 00:01:09 2-12:48:54 122718 /opt/dynatrace/oneagent/agent/lib64/oneagentwatchdog -bg -config=/opt/dynatrace/oneagent/agent/conf/watchdog.conf
8:devices:/system.slice/oneagent.service,1:name=systemd:/system.slice/oneagent.service root 777564 47072 00:15:38 2-12:48:54 122727 oneagentos -Dcom.compuware.apm.WatchDogPort=50000 -Dcom.compuware.apm.WatchDogTimeout=900 -watchdog.restart_file_location=/var/lib/dynatrace/oneagent/agent/runtime/watchdog_restart_file
8:devices:/system.slice/oneagent.service,1:name=systemd:/system.slice/oneagent.service root 639836 11948 00:05:28 2-12:48:54 122734 oneagentloganalytics -Dcom.compuware.apm.WatchDogPort=50002 -Dcom.compuware.apm.WatchDogTimeout=900
8:devices:/system.slice/oneagent.service,1:name=systemd:/system.slice/oneagent.service dtuser 427324 166280 00:02:22 2-12:48:54 122740 oneagentnetwork -Dcom.compuware.apm.WatchDogPort=50003 -Dcom.compuware.apm.WatchDogTimeout=900
8:devices:/system.slice/oneagent.service,1:name=systemd:/system.slice/oneagent.service dtuser 571748 47344 00:01:48 2-12:47:40 123039 oneagentplugin -Dcom.compuware.apm.WatchDogPort=50001 -Dcom.compuware.apm.WatchDogTimeout=900
<<<mem>>>
MemTotal:        7990092 kB
MemFree:          236720 kB
MemAvailable:    1814448 kB
Buffers:            5364 kB
Cached:          1737236 kB
SwapCached:          776 kB
Active:          5449084 kB
Inactive:        1793240 kB
Active(anon):    4436472 kB
Inactive(anon):  1119692 kB
Active(file):    1012612 kB
Inactive(file):   673548 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:       4161532 kB
SwapFree:        4132228 kB
Dirty:              1624 kB
Writeback:             0 kB
AnonPages:       5498924 kB
Mapped:           171816 kB
Shmem:             56440 kB
Slab:             283636 kB
SReclaimable:     197412 kB
SUnreclaim:        86224 kB
KernelStack:        7296 kB
PageTables:        20852 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     8156576 kB
Committed_AS:    6552724 kB
VmallocTotal:   34359738367 kB
VmallocUsed:      194508 kB
VmallocChunk:   34359310332 kB
Percpu:            28672 kB
HardwareCorrupted:     0 kB
AnonHugePages:   4839424 kB
CmaTotal:              0 kB
CmaFree:               0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
DirectMap4k:      157568 kB
DirectMap2M:     7182336 kB
DirectMap1G:     3145728 kB
<<<cpu>>>
1.51 0.83 0.50 3/328 11799 1
62235
<<<uptime>>>
595480.34 526986.92
<<<lnx_if>>>
[start_iplink]
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 00:50:56:89:8b:82 brd ff:ff:ff:ff:ff:ff
    inet x.x.x.x/24 brd  x.x.x.x scope global eth0
    inet6 fe80::250:56ff:fe89:8b82/64 scope link
[end_iplink]
<<<lnx_if:sep(58)>>>
  eth0: 417194262550 45154755    0    0    0     0          0      4835 6791988303 35813333    0    0    0     0       0          0
    lo: 19027108  316874    0    0    0     0          0         0 19027108  316874    0    0    0     0       0          0
[lo]
	Link detected: yes
	Address: 00:00:00:00:00:00
[eth0]
	Speed: 10000Mb/s
	Duplex: Full
	Auto-negotiation: off
	Link detected: yes
	Address: 00:50:56:89:8b:82
<<<tcp_conn_stats>>>
01 32
02 1
0A 15
06 1
<<<diskstat>>>
1645050402
   8       0 sda 41096 19 3202713 158672 637723 33241 23854443 3028184 0 1003929 3186712
   8       1 sda1 386 0 14080 1558 71 0 4120 285 0 1770 1843
   8       2 sda2 40620 19 3183465 156693 637652 33241 23850323 3027899 0 1003530 3184448
   8      16 sdb 326 82 12208 1237 502 6861 58904 8162 0 4433 9398
   8      32 sdc 54060 36 2631622 321047 68103 9060 7279812 4576<<<esx_vsphere_vm:cached(1645050200,90)>>>
time_reference 1645050199
config.datastoreUrl name MYVMDATASTORE|accessible true|capacity 8795824586752|freeSpace 4771545088000|maintenanceMode normal|type VMFS|uncommitted 120375490931|url ds:///vmfs/volumes/5e9c903b-97553d6c-434e-eaa0f06000f3/
config.guestFullName Oracle Linux 4/5 or later (64-bit)
config.hardware.device virtualDeviceType VirtualCdrom|label CD/DVD drive 1|summary Remote ATAPI|startConnected false|allowGuestControl true|connected false|status ok@@virtualDeviceType VirtualVmxnet3|label Network adapter 1|summary DVSwitch: dc aa 09 50 2f f2 07 84-e1 b2 6f d1 5a 15 4a b4|startConnected true|allowGuestControl true|connected true|status ok
config.hardware.memoryMB 8192
config.hardware.numCPU 1
config.hardware.numCoresPerSocket 1
config.template false
config.uuid 42094928-6ddd-913b-73cc-b204c853d922
config.version vmx-11
guest.toolsVersion 11269
guest.toolsVersionStatus guestToolsUnmanaged
guestHeartbeatStatus green
name MYHOST
runtime.host MYVMWARE
runtime.powerState poweredOn
summary.guest.hostName MY-HOST
summary.quickStats.balloonedMemory 0
summary.quickStats.compressedMemory 0
summary.quickStats.consumedOverheadMemory 49
summary.quickStats.distributedCpuEntitlement 329
summary.quickStats.distributedMemoryEntitlement 5752
summary.quickStats.guestMemoryUsage 3850
summary.quickStats.hostMemoryUsage 8073
summary.quickStats.overallCpuDemand 1139
summary.quickStats.overallCpuUsage 1139
summary.quickStats.privateMemory 8024
summary.quickStats.sharedMemory 0
summary.quickStats.staticCpuEntitlement 1206
summary.quickStats.staticMemoryEntitlement 8486
summary.quickStats.swappedMemory 0
summary.quickStats.uptimeSeconds 3564982
<<<labels:sep(0)>>>
{"cmk/piggyback_source_MY-VMCENTER": "yes"}
I’m facing issue with Check_MK agents constantly going from OK to WARN all the time, this is availability data of one of the affected hosts from last 24h:
I have many Linux machines with such problem, after Baking Agents some of them stopped to send data from certain checks like:
and I don’t know how to get them healthy again. What I’ve tried on affected hosts to fix them:
  1. Services > Actions > Remove all and find new
  2. Restart OMD Site
  3. Piggyback cleanup
Do You know how can I troubleshoot this issue deeper?
There is clearly something broken with your agent installation. The <<<esx_vsphere_vm:...>>> stanza should be in a new line, not in the same line with the output of the section before.
It is hard to say what went wrong. I would try to deactivate all local checks and agent plugins (and delete their cache entries). Then, activate them one by one and check which one causes the error.
It is also recommended to use an agent version near the server version, e.g. 2.0.0p19 or just slightly older.
How many monitoring software agents are running on this system?
Telegraf
Munin agent
Filebeat
Dynatrace
CMK agent
Is it possible that something interferes with the execution of the CMK agent?
If every time the same sections are missing then there is a problem with the output of a special section. In your example output the “diskstat” section is not complete.
Hi, I can chime in here. We have the same issue on multiple hosts that are not as intensely monitored as the one posted by dominikskorupa.it. One other host that does have telegraf installed but disabled, and none of the other monitoring tools exhibits the same behavior.
Here we can see that the piggybacked section starts midway through the kernel section. Note that the injection does not always occur in the same place.
Running the agent locally yields the entire output without issues.
cannot post that image here (new user). So you just have to trust me :slight_smile:
I would have thought this issue would reside on the MK server-side as the piggyback data sits there and is only visible when MK itself invokes the agent.
Hello again and thank You for all answers.
I took one host to look closer for ESX section. One time it’s in good line(and all sensors data are collected fine) and the other time it shows in unexpected place braking part of check data.
Here is agent output where checks had no issues:
<<<job>>>
<<<local:sep(0)>>>
0 Check_If_Reboot_Required pkg_count=0 OS is OK, reboot not required.
<<<logins>>>
0
<<<sslcertificates:cached(1644932054,3600)>>>
<<<check_mk:cached(1644934766,600)>>>
AgentUpdate: last_check 1644934764.4726405 last_update 1644934766.215456 aghash 1f08a3f9b9acbc30 pending_hash None update_url https://mysite/main error None
<<<esx_vsphere_vm:cached(1645175291,90)>>>
time_reference 1645175289
config.datastoreUrl name MYDATASTORE|accessible true|capacity 8795824586752|freeSpace 5715626295296|maintenanceMode normal|type VMFS|uncommitted 1111186493364|url ds:///vmfs/volumes/5e974330-e3d2f23d-ead8-eaa0f06000f3/
config.hardware.memoryMB 2048
config.uuid 4209370b-f5e3-6912-9cc9-0a8f7beab313
config.version vmx-10
guest.toolsVersion 10336
name MY-HOST
runtime.host MY-VMWARE
summary.quickStats.consumedOverheadMemory 30
summary.quickStats.distributedCpuEntitlement 59
summary.quickStats.distributedMemoryEntitlement 1072
summary.quickStats.guestMemoryUsage 307
summary.quickStats.hostMemoryUsage 2036
summary.quickStats.overallCpuDemand 59
summary.quickStats.overallCpuUsage 29
summary.quickStats.privateMemory 2005
summary.quickStats.sharedMemory 11
summary.quickStats.staticCpuEntitlement 1211
summary.quickStats.staticMemoryEntitlement 2284
summary.quickStats.uptimeSeconds 3797702
<<<labels:sep(0)>>>
{"cmk/piggyback_source_MYVMCENTER": "yes"}
And here is the end of output where certain checks gave no info:
01 8
0A 9
06 1
<<<diskstat>>>
1645178849
   8       0 sda 32205 8 2231292 124962 378482 39716 17240987 1823784 0 647049 1948658
   8       1 sda1 2175 0 14055 6646 4 0 4096 44 0 6583 6689
   8       2 sda2 29941 8 2212077 117863 378478 39716 17236891 1823740 0 640743 1941516
   8      16 sdb 285 267 13360 1129 90 812 7216 4804 0 3694 5933
   8      32 sdc 3683 23 136205 13855 59243 6509 1012791 279615 0 215725 293459
 253       0 dm-0 29740 0 2199060 116971 369327 0 16416956 1871213 0 454306 1988199
 253       1 dm-1 486 0 11096 2169 902 0 7216 54672 0 3427 56841
 253       2 dm-2 178 0 11033 820 48867 0 819935 196603 0 187932 197425
 253       3 dm-3 3622 0 134045 13807 65752 0 1012791 338652 0 215615 352464
[dmsetup_info]
rootvg-tmp <<<esx_vsphere_vm:cached(1645178662,90)>>>
time_reference 1645178660
config.datastoreUrl name my-datastore-url|accessible true|capacity 8795824586752|freeSpace 5715626295296|maintenanceMode normal|type VMFS|uncommitted 1111186493364|url ds:///vmfs/volumes/5e974330-e3d2f23d-ead8-eaa0f06000f3/
name MY-HOST
summary.guest.hostName  MYHOSTNAME
summary.quickStats.distributedCpuEntitlement 89
summary.quickStats.distributedMemoryEntitlement 1011
summary.quickStats.guestMemoryUsage 491
summary.quickStats.overallCpuDemand 89
summary.quickStats.overallCpuUsage 89
summary.quickStats.uptimeSeconds 3801062
<<<labels:sep(0)>>>
I’m 99% sure that it’s always DISKSTAT section getting broken by ESX on every affected host, but will have to make sure by looking on more agent outputs. After DISKSTAT there should be sections like:
<<<kernel>>>
<<<md>>>
<<<vbox_guest>>>
<<<chrony:cached(1645175361,30)>>>
<<<postfix_mailq>>>
<<<postfix_mailq_status:sep(58)>>>
<<<fileinfo:sep(124)>>>
<<<job>>>
<<<local:sep(0)>>>
<<<logins>>>
and when they are missing it’s of course reflected with Check_MK Warn:
Missing monitoring data for check plugins: chrony, fileinfo_groups, kernel_performance, kernel_util, local, logins, postfix_mailq, postfix_mailq_status
Do You think it can be caused by Linux diskstat check or the piggyback mechanism?
This is not a problem of the ESX data. The piggyback data is automatically appended to the agent output. If the agent output ends without a line break or is generally broken then the ESX sections starts directly in this line.
I would recommend to inspect the affected machines if there are any errors on execution of the agent.
On machines without piggyback data the agent output is simply broken and some checks are missing.
Execution of the agent on the affected machines appears to work without issue.
Running cmk -d FQDN for one of the affected machines returns the following (omitting sections before and after the issue)
·······valid_lft·forever·preferred_lft·forever¶
[end_iplink]¶
<<<lnx_if:sep(58)>>>¶
ens192:·88880750502·178724780····0··222····0·····0··········0······7127·626059884·1475841····0····0····0·····0·······0··········0¶
····lo:····6502······86····0····0····0·····0··········0·········0·····6502······86····0····0····0·····0·····<<<esx_vsphere_vm:cached(1646299525,90)>>>¶
time_reference·1646299523¶
note that I’ve replaced whitespace characters to highlight them with the following alias alias whitespace='sed '\''s/ /·/g;s/\t/→/g;s/\r/§/g;s/$/¶/g'\'''
Running the check locally works fine, as seen here
[end_iplink]¶
ens192:·88862266413·178689154····0··222····0·····0··········0······7126·625487056·1475583····0····0····0·····0·······0··········0¶
····lo:····6502······86····0····0····0·····0··········0·········0·····6502······86····0····0····0·····0·······0··········0¶
[lo]¶
→Link·detected:·yes¶
→Address:·00:00:00:00:00:00¶
To add, the only difference in execution is that the MK agent data being sent to the MK server is encrypted while the output on the affected machine is run by a non-root user as the root execution just returns encrypted gibberish.
Update: Disabling encryption on affected hosts seems to resolve the issue, not ideal at all. Are there any known issues with encryption?
I skipped through the post and as has been pointed out some times, there is little possibility for Checkmk to interfere here. It looks to me like there is something interfering on the transport. Especially, as you pointed out, that disabling encryption helps. There are no known issues with encryption, but “smart firewalls” or WAF are known to interfere with that kind of traffic. Possibly one of those systems dislikes the encrypted data stream and cuts it. That would explain your issue.
