Missing port parameter in Docker configuration
In the manual for Docker installation the port for agent authentication (8000) is missing.
The instruction for the Docker command reads like:
docker container run -dit -p 8080:5000 --tmpfs /opt/omd/sites/cmk/tmp:uid=1000,gid=1000 -v monitoring:/omd/sites --name monitoring -v /etc/localtime:/etc/localtime:ro --restart always checkmk/check-mk-raw:2.0.0-latest
Should be:
docker container run -dit -p 8080:5000 -p 8000:8000 --tmpfs /opt/omd/sites/cmk/tmp:uid=1000,gid=1000 -v monitoring:/omd/sites --name monitoring -v /etc/localtime:/etc/localtime:ro --restart always checkmk/check-mk-raw:2.0.0-latest
Without the defintion of Port 8000 agents aren’t able to connect with cmk.
Running into SSL Handshake error or connection timeout.
See: SSL Handshake Fehler bei Registrierung des Agenten (GERMAN)
Chris
Oh, man… we probably should have caught this one. Thanks for reporting this. I will add it to the official guide now, and it will be visible latest next week.
I will, of course, also change the referenced image to Checkmk 2.1.0.
→ check-mk-raw:2.1.0-latest
Sorry for the delay. Here is the commit:
The change will be visible on docs.checkmk.com by tomorrow.
