The cisco_redundancy check is missing some new swact_reason codes causing the check to crash.
def check_cisco_redundancy(_no_item, params, info):
map_states = {
"unit_state": {
"0": "not found",
"1": "not known",
"2": "disabled",
"3": "initialization",
"4": "negotiation",
"5": "standby cold",
"6": "standby cold config",
"7": "standby cold file sys",
"8": "standby cold bulk",
"9": "standby hot",
"10": "active fast",
"11": "active drain",
"12": "active pre-config",
"13": "active post-config",
"14": "active",
"15": "active extra load",
"16": "active handback",
"duplex_mode": {
"2": "False (SUB-Peer not detected)",
"1": "True (SUB-Peer detected)",
"swact_reason": {
"1": "unsupported",
"2": "none",
"3": "not known",
"4": "user initiated",
"5": "user forced",
"6": "active unit failed",
"7": "active unit removed",
It is specifically missing enums 8 and 9, I have attached the updated .mib
CISCO-RF-MIB.txt (55.8 KB)
but I have also pasted the relevant sections below:
DESCRIPTION
"Added descriptions for enums 8 and 9 in RFSwactReasonType"
REVISION "202307130000Z"
RFSwactReasonType ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"Reason codes for the switch of activity from an active
redundant unit to its standby peer unit.
unsupported
- the 'reason code' is an unsupported feature
none
- no SWACT has occurred
notKnown
- reason is unknown
userInitiated
- a safe, manual SWACT was initiated by user
userForced
- a manual SWACT was forced by user; ignoring
pre-conditions, warnings and safety checks
activeUnitFailed
- active unit failure caused an auto SWACT
activeUnitRemoved
- active unit removal caused an auto SWACT
activeGWdown
- SWACT due to active losing gateway connectivity
activeRMIportdown
- SWACT due to RMI port going down on active"
SYNTAX INTEGER {
unsupported(1),
none(2),
notKnown(3),
userInitiated(4),
userForced(5),
activeUnitFailed(6),
activeUnitRemoved(7),
activeGWdown(8),
activeRMIportdown(9)
Was not sure the best place to post this as the feedback forum seems to be closed for new posts? But how does one go about getting these official checks fixed? Currently I go in an manually edit the file to add the missing checks, but this is annoying as it must be done anytime cmk is updated.
Thanks!
