updating to 2.1.0p29 did not fix the problem =(
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/decorator.py", line 43, in wrapped_check_func
status, output_text = _combine_texts(check_func(hostname, *args, **kwargs))
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/discovery/__init__.py", line 581, in active_check_discovery
services = _get_host_services(
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/discovery/__init__.py", line 1030, in _get_host_services
**_get_node_services(
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/discovery/__init__.py", line 1055, in _get_node_services
service_result = analyse_discovered_services(
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/discovery/_discovered_services.py", line 46, in analyse_discovered_services
discovered_services=_discover_services(
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/discovery/_discovered_services.py", line 145, in _discover_services
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/discovery/_discovered_services.py", line 145, in <dictcomp>
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/discovery/_discovered_services.py", line 280, in _discover_plugins_services
yield from (
File "/omd/sites/vls/lib/python3/cmk/base/agent_based/discovery/_discovered_services.py", line 280, in <genexpr>
yield from (
File "/omd/sites/vls/lib/python3/cmk/base/api/agent_based/register/check_plugins.py", line 74, in filtered_generator
for element in generator(*args, **kwargs):
File "/omd/sites/vls/lib/python3/cmk/base/plugins/agent_based/logwatch.py", line 120, in discover_logwatch_groups
not_forwarded_logs = logwatch.select_forwarded(
File "/omd/sites/vls/lib/python3/cmk/base/plugins/agent_based/utils/logwatch.py", line 106, in select_forwarded
return {
File "/omd/sites/vls/lib/python3/cmk/base/plugins/agent_based/utils/logwatch.py", line 107, in <setcomp>
item for item in items if ec_forwarding_enabled(forward_settings[0], item) is not invert
File "/omd/sites/vls/lib/python3/cmk/base/plugins/agent_based/utils/logwatch.py", line 93, in ec_forwarding_enabled
return any(re.match(pattern, item) for pattern in params["restrict_logfiles"])
File "/omd/sites/vls/lib/python3/cmk/base/plugins/agent_based/utils/logwatch.py", line 93, in <genexpr>
File "/omd/sites/vls/lib/python3.9/re.py", line 191, in match
return _compile(pattern, flags).match(string)
File "/omd/sites/vls/lib/python3.9/re.py", line 304, in _compile
p = sre_compile.compile(pattern, flags)
File "/omd/sites/vls/lib/python3.9/sre_compile.py", line 788, in compile
p = sre_parse.parse(p, flags)
File "/omd/sites/vls/lib/python3.9/sre_parse.py", line 955, in parse
p = _parse_sub(source, state, flags & SRE_FLAG_VERBOSE, 0)
File "/omd/sites/vls/lib/python3.9/sre_parse.py", line 444, in _parse_sub
itemsappend(_parse(source, state, verbose, nested + 1,
File "/omd/sites/vls/lib/python3.9/sre_parse.py", line 526, in _parse
code = _escape(source, this, state)
File "/omd/sites/vls/lib/python3.9/sre_parse.py", line 427, in _escape
raise source.error("bad escape %s" % escape, len(escape))
Josef
