Mk-sql: is it possible to get it to not try the login @ offline databases
CMK 2.3
The SQL event log has 4 attempts to login/min for every offline database (only 4, for now …). Seems like it should be the default to not try to login to offline databases?
Am I missing an option/setting somewhere?
Did you ever get this resolved? I get the same issue.
Hi @festerman
We discussed this recently in this post:
That feature was introduced recently in version 2.5.0p8.
No idea if a workaround for version 2.3.
Hope this helps,
David
