Mkeventd.log problems >> error messages like: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 100: invalid start byte
2.2.0p21.cee
Ubuntu 20.04.6 LTS
our site is running fine - for some time / after some days we see errors in the event processing:
mkeventd.log
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xb0 in position 100: invalid start byte
2024-02-16 15:54:16,014 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
File “/omd/sites/cb/lib/python3/cmk/ec/main.py”, line 235, in run
self.serve()
File “/omd/sites/cb/lib/python3/cmk/ec/main.py”, line 744, in serve
self.process_raw_lines(message, address)
File “/omd/sites/cb/lib/python3/cmk/ec/main.py”, line 794, in process_raw_lines
if line := scrub_string(line_bytes.rstrip().decode(“utf-8”)):
2024-02-16 16:10:14,034 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xb0 in position 99: invalid start byte
2024-02-16 16:10:16,501 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xc4 in position 104: invalid continuation byte
2024-02-16 16:10:55,034 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:11:16,034 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:13:52,578 [20] [cmk.mkeventd.StatusServer] Executing command: DELETE;1093339,1093340,1093341,1093342,1093337,1093338;pronexon
2024-02-16 16:27:14,093 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:27:16,903 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:27:55,109 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:28:16,108 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:44:14,133 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:44:17,315 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:44:55,123 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
2024-02-16 16:45:16,127 [40] [cmk.mkeventd.EventServer] Exception in EventServer server
self.serve()
any ideas?
That’s an Ä
That’s a °
Maybe you have devices that are sending those ascii chars?
could be that there are such devices - sending such characters … but they should not crash the mkeventd … I need to restart the mkeventd … only after the restart the processing works again …
that the behavior that I have seen so far … maybe there is also another reason for this (file limits etc. … that’s what I already checked)
any solution ideas how to prevent such an error or how to find more about the problem are welcome …
