CMK version: 2.2.0p20 (latest raw)
OS version: Fedora 38
Error message: is much the same for several other addons I tried
OMD[house]:~$ mkp inspect /tmp/lmsensors2-1.0.mkp
OMD[house]:~$ mkp show-all
Local extension packages
Shipped extension packages
OMD[house]:~$ mkp add /tmp/lmsensors2-1.0.mkp
OMD[house]:~$ mkp list
Name Version Title Author Req. Version Until Version Files State
OMD[house]:~$
[root@bookcase house]# su - house
Last login: Wed Jan 24 22:07:21 GMT 2024 on pts/0
egrep: warning: egrep is obsolescent; using grep -E
OMD[house]:~$ cmk --debug -vvn hostname
Checkmk version 2.2.0p20
Failed to lookup IPv4 address of hostname via DNS: [Errno -3] Temporary failure in name resolution
OMD[house]:~$ cmk --debug -vvn localhost
Updating IPv4 DNS cache for localhost: 127.0.0.1
Trying to acquire lock on /omd/sites/house/var/check_mk/ipaddresses.cache
Got lock on /omd/sites/house/var/check_mk/ipaddresses.cache
Releasing lock on /omd/sites/house/var/check_mk/ipaddresses.cache
Released lock on /omd/sites/house/var/check_mk/ipaddresses.cache
+ FETCHING DATA
Source: SourceInfo(hostname='localhost', ipaddress='127.0.0.1', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7fcca0f86c50]
Read from cache: NoCache(localhost, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'localhost'. Skip processing.
No piggyback files for '127.0.0.1'. Skip processing.
[cpu_tracking] Stop [7fcca0f86c50 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
HostKey(hostname='localhost', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fcca04acb10]
value store: synchronizing
Trying to acquire lock on /omd/sites/house/tmp/check_mk/counters/localhost
Got lock on /omd/sites/house/tmp/check_mk/counters/localhost
Releasing lock on /omd/sites/house/tmp/check_mk/counters/localhost
Released lock on /omd/sites/house/tmp/check_mk/counters/localhost
[cpu_tracking] Stop [7fcca04acb10 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[piggyback] Success (but no data found for this host), execution time 0.0 sec | execution_time=0.000 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.000
OMD[house]:~$
