CMK version: 2.3.0p41
OS version: Debian 12
Error message: ModuleNotFoundError: No module named ‘cmk.special_agents.utils.agent_common’
cmk --debug -vvn 127.0.0.1
Ignoring outdated plugin ‘gitlab_runner’: Format no longer supported – this API is deprecated!
Ignoring outdated plugin ‘modbus_value’: Format no longer supported – this API is deprecated!
value store: synchronizing
Trying to acquire lock on /omd/sites/gf1/tmp/check_mk/counters/127.0.0.1
Got lock on /omd/sites/gf1/tmp/check_mk/counters/127.0.0.1
Releasing lock on /omd/sites/gf1/tmp/check_mk/counters/127.0.0.1
Released lock on /omd/sites/gf1/tmp/check_mk/counters/127.0.0.1
Checkmk version 2.3.0p41
- FETCHING DATA
Source: SourceInfo(hostname=‘127.0.0.1’, ipaddress=‘127.0.0.1’, ident=‘special_ilo’, fetcher_type=<FetcherType.SPECIAL_AGENT: 6>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f3755df7230]
Read from cache: AgentFileCache(127.0.0.1, path_template=/omd/sites/gf1/tmp/check_mk/data_source_cache/special_ilo/{hostname}, max_age=MaxAge(checking=0, discovery=225.0, inventory=225.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (does not exist)
Calling: /omd/sites/gf1/local/share/check_mk/agents/special/agent_ilo --server 127.0.0.1 --user test --password test
Get data from program
[cpu_tracking] Stop [7f3755df7230 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.04, children_system=0.0, elapsed=0.05000000074505806))]
Source: SourceInfo(hostname=‘127.0.0.1’, ipaddress=‘127.0.0.1’, ident=‘piggyback’, fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f3755f31c10]
Read from cache: NoCache(127.0.0.1, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for ‘127.0.0.1’. Skip processing.
Get piggybacked data
[cpu_tracking] Stop [7f3755f31c10 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f375791bd70] - PARSE FETCHER RESULTS
HostKey(hostname=‘127.0.0.1’, source_type=<SourceType.HOST: 1>) → Add sections:
Received no piggyback data
[cpu_tracking] Stop [7f375791bd70 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[special_ilo] ModuleNotFoundError: No module named ‘cmk.special_agents.utils.agent_common’(!!), [piggyback] Success (but no data found for this host), execution time 0.1 sec | execution_time=0.050 user_time=0.000 system_time=0.000 children_user_time=0.040 children_system_time=0.000 cmk_time_ds=0.010 cmk_time_agent=0.000
Agent exited with code 1: Traceback (most recent call last):
File “/omd/sites/gf1/local/share/check_mk/agents/special/agent_ilo”, line 27, in
from cmk.special_agents.utils.agent_common import (
I just upgraded to last 2.3, hpe_ilo 4.0.2 and nutanix_prism 5.0.7
I have this message when I try to use 2 plugins above. I guess I would have the problem with any special agent coming through plugins.
