Monitor ansible playbooks with checkmk
We run several ansible playbooks each day for our hosts full automated. Each status is then mailed to our team. Is there a module or easy way to send the playbook results directly to checkmk? I found a lot about ansible automated installs of checkmk components or configuration of sites but nothing in my direction.
How are you running the playbooks? From a scheduling app such as Rundeck, via AWX, or cron?
One generic approach could be to write output to a file as the final task in the playbook and write a local check to test the success/fail condition.
Alternatively you could set the syslog options for Ansible output and use the Event Console to handle the messages as required.
We use cron - its a small environment. Using local checks is an option (we use very often) but I expected to find some modules already available. Event cosole is an idea, but we do not use it till now.
Thx
You can use mk-job for that: Monitoring time-based processes (Cronjobs)
Another possibility is to convert them to systemd timers. The effect is that
  1. the output is available via the journal without redirection magic
  2. CheckMK monitors systemd service status out of the box, meaning a failing timer invocation will be noticed by CheckMK right away without any kind of special setup
Thanks for suggestions. I will have a closer look at systemd timers and mk-job.
