Monitor apache httpd for process count
Hi i am testing check-mk2.2
i wish to monitor apache httpd, for process count, if httpd process exceeds 40 count , we should receive Warn , and Ok(if process count 1 to 30 ) and CRITICAL if exceeds 60 .
how i can set the same ? currently
currenyl in apache plugin only, busy workers and Open Slots are allowed to configure
The Apache plugin is not for the process count monitoring.
Here you should use the rule “Service monitoring rules” → “State and count of processes”. It is possible to define a direct process name or a regular expression what you want to find.
hi Andreas
Thanks for the Reply.
i tried configuring Service monitoring rule (State and count of processes) as shown in screen-shot.but its not detecting mentioned services. it seems i m missing something here .
Sorry one more rule is needed under → “Service discovery rules” → “Process discovery”
The system needs to know what processes you want to discover.
Inside this rule you can already define default parameter. But i would use the other rule for the parameters.
hi Andereas
its working now , thanks.
hi Andreas
Thanks for the reply.
i want to check 2 strings in processname , how we can check that ?
ps auwx | grep -i sendsms | grep tomcat9j11
The command line can be a complex regex.
I would test my regex inside a tool like regex101.com
Thanks andreas for the reply.
