CMK version:2.0.0p27 CEE
OS version:RHEL 7.4
I cannot display my Business Intelligence aggregations because that view is not displayed in Monitor as described in oficial Documentation.
This is what it is displayed:
OS version:RHEL 7.4
Did you enable at least one “Business Intelligence”?
Enable BI? Normally it cannot be switched off. It looks like a permission problem. That’s the only way i know to “disable” the BI views.
The setting inside the role setup should be → Topics → Business Intelligence
it’s switched off by default in new installations.
If you enable at least one rule, you will see the menu entries.
BUT, in 2.0 you might have to reload the whole page (f5), this is a bug fixed only in 2.1 at the moment
I meant what @_rb said. Thanks for the more eloquent answer, buddy! ![]()
