Hello group
Is It possible to monitor file size, age ect on Netapp unc path?
Oded
Hello group
Oded
Not so easy
If you have a normal SMB share on your NetApp then you need some check who mounts this share and reads / lists the files.
For such tasks i build a small python script using the pysmb lib. This lib is well documented.
You could mount that share on a Linux box and use the fileinfo plugin from there.
Just mount the share to either a windows or linux box monitored with the check_mk_agent and use the fileage check.
Only possible to do this from Linux like @r.sander said.
Windows agent is not easy to present a mapped drive to local system account.
