I edited the code and now it works !
#self._base_url = “https://%s/v3/api/” % self._host
self._base_url = “http://%s/api/” % self._host
But still have a problem(crash output) with some services
Here is crash details:
Any idea about the crash details?!
File “/omd/sites/mysite/lib/python/cmk_base/checking.py”, line 322, in execute_check
cmk_base.check_utils.is_snmp_check(check_plugin_name))
File “/omd/sites/mysite/lib/python/cmk_base/checking.py”, line 444, in sanitize_check_result
return _sanitize_yield_check_result(result, is_snmp)
File “/omd/sites/mysite/lib/python/cmk_base/checking.py”, line 450, in _sanitize_yield_check_result
subresults = list(result)
File “/omd/sites/mysite/share/check_mk/checks/hp_msa_volume”, line 209, in check_hp_msa_volume_df
parsed = _get_item_data(item, parsed)
File “/omd/sites/mysite/share/check_mk/checks/hp_msa_volume”, line 142, in _get_item_data
if item in [k, v[“durable-id”]]:
{‘item’: u’san1_FTP_en2_R5_FTP’,
‘k’: u’san1_vd2_en1_R50_v1’,
‘parsed’: {u’san1_FTP_en2_R5_FTP’: {u’blocks’: u’1145719808’,
u’bytes-per-second’: u’4608B’,
u’bytes-per-second-numeric’: u’4608’,
u’cache-optimization’: u’standard’,
u’cache-optimization-numeric’: u’0’,
u’capabilities’: u’dme’,
u’container-name’: u’FTP_en2_R5_D21-25’,
u’container-serial’: u’00c0ff13c8fd00005c069e5b00000000’,
u’data-read’: u’1531.8MB’,
u’data-read-numeric’: u’1531888640’,
u’data-written’: u’9565.1MB’,
u’data-written-numeric’: u’9565119488’,
u’full-stripe-write-destages’: u’28732’,
u’iops’: u’1’,
u’number-of-reads’: u’123780’,
u’number-of-writes’: u’351206’,
u’owner’: u’B’,
u’owner-numeric’: u’0’,
u’preferred-owner’: u’B’,
u’preferred-owner-numeric’: u’0’,
u’progress’: u’0%’,
u’progress-numeric’: u’0’,
u’read-ahead-operations’: u’13189’,
u’read-ahead-size’: u’Default’,
u’read-ahead-size-numeric’: u’-1’,
u’read-cache-hits’: u’154570’,
u’read-cache-misses’: u’36694’,
u’serial-number’: u’00c0ff13c8fd00001c079e5b01000000’,
u’size’: u’586.6GB’,
u’size-numeric’: u’1145719808’,
u’small-destages’: u’21101’,
u’virtual-disk-name’: u’FTP_en2_R5_D21-25’,
u’virtual-disk-serial’: u’00c0ff13c8fd00005c069e5b00000000’,
u’volume-class’: u’standard’,
u’volume-class-numeric’: u’0’,
u’volume-name’: u’san1_FTP_en2_R5_FTP’,
u’volume-qualifier’: u’N/A’,
u’volume-qualifier-numeric’: u’0’,
u’volume-type’: u’standard’,
u’volume-type-numeric’: u’0’,
u’write-cache-hits’: u’319400’,
u’write-cache-misses’: u’533693’,
u’write-cache-percent’: u’12’,
u’write-cache-space’: u’52’,
u’write-policy’: u’write-back’,
u’write-policy-numeric’: u’1’,
u’wwn’: u’600C0FF00013C8FD1C079E5B01000000’},
