Today, I had a very slow upload speed. I wanted to find a way to know where the problem was (very slow for upload). How to see which app on my system is consuming the most traffic ? For example, Google chrome was consuming 60% of the traffic but I have not figured out a way how to check this in Checkmk.
slow internet connections could be caused by tons of reasons.
1)
monitor your workstation using the default checks
2)
check a target system outside using http checks to verify the performance over a longer period
Don t use a public system, use an own site outside.
Ralf
Thanks @rprengel . The workstation is already being monitored by the default checks but I don’t know which check gives me the information about the internet usage.
Can this tell me which application is consuming most of my internet bandwidth out of the box ?
