I have a bunch of HPE 2920 aruba switches and noticed in the CheckMK 1.6.0p9 RAW version I cannot see under the recently added host that the stack port shows up as an available “monitored service”.
If I upgrade our CheckMK to a later version would monitoring the stack port on aruba switches be available?
Thank you for the suggestion Alex, I followed that guide earlier setting up the network switches and was only able to monitor the fiber uplink for each one. As it stands now I believe I can’t monitor the stack ports, but monitoring the uplink should suffice for now since this would indicate bigger problems happening between the switch and core.
Again thank you for the recommendation, it is greatly appreciated!
