Hello All,
I have two servers called Node 1 and Node2, there is a service that is monitored on both but only on one of the nodes (usually the primary node) the service has status “OK” and on the secondary node it has critical status because it is not being executed over there; Only if I change the node service can we see the “OK” service on the secondary node.
How can I configure them so that on the node that is not running the alert is not in critical state and only reports if the service is not running on both nodes?
NODE1
NODE2
Thanks in advance.
Regards.
Victor
