I am trying to monitor the temperature through an online weatherservice, using curl and jq. I have created a bash script as a local check and put it in /lib/check_mk_agent/plugins/.
Edit: It is in the /usr/lib/check_mk_agent/local directory.
From the monitored host it works fine calling the script directly on the commandline and when I run the check_mk_agent it also works.
The plugin is discovered in CheckMK, and is receiving content, but for some reason the value (temperature) gathered by curl and jq is not passed to the CheckMK Server. Everything else is.
The content is sent from bash as:
echo “P "Temperature" myvalue=$value;20;30 It is $value degrees outside”
Should also note that the Checkmk Server it self does not have access to internet via curl.
I hope someone in this forum have an idea to what causes this
dabrain
(Andreas Breuer)
July 19, 2023, 7:20am
2
local checks should be placed at: /usr/lib/check_mk_agent/local/
directory
When you call the check_mk_agent you should see your script output below the <<<local>>>
part of the agent like:
check_mk_agent | grep -v grep | grep -A2 "<<<local"
<<<local>>>
P "Temperature" myvalue=25;20;30 It is 25 degrees outside
Further details at: Local checks
kdeutsch
(Karl Deutsch)
July 19, 2023, 7:32am
3
can you show your script?
Karl
The script is located in /usr/lib/check_mk_agent/local, it was a typo
Here is the output from your command at my host:
$ check_mk_agent | grep -v grep | grep -A2 "<<<local"
<<<local:sep(0)>>>
P "Temperature" count=8.4;20;30 It is 8.4 degrees outside
Strange thing though, if I collect the temperature to a file, with crontab each hour, and then read it from the file instead, it works fine
Hi, of course, here it is:
#!/bin/sh
count=$(curl 'https://api.met.no/weatherapi/locationforecast/2.0/compact?lat=60.38721&lon=5.97101&altitude=500' | jq .properties.timeseries[1].data.instant.details.air_temperature)
echo "P \"Temperature\" count=$count;20;30 It is $count degrees outside"
kdeutsch
(Karl Deutsch)
July 19, 2023, 9:01am
6
Hi @ronny.gronsdal ,
I tested your script on Checkmk 2.1.0p26. That’s the result:
It work’s for me.
Karl
hi @kdeutsch , that sure is strange…
Can I ask if your checkmk server have access to internet, i.e. can it ping api.met.no?
Ronny
kdeutsch
(Karl Deutsch)
July 19, 2023, 9:17am
8
Checkmk server and monitored host are the same und have access to internet.
Karl
kdeutsch
(Karl Deutsch)
July 19, 2023, 9:26am
9
I modified your script a little bit to use piggyback data. This works for me also:
#!/bin/sh
count=$(curl -s 'https://api.met.no/weatherapi/locationforecast/2.0/compact?lat=60.38721&lon=5.97101&altitude=500' | jq .properties.timeseries[1].data.instant.details.air_temperature)
echo "<<<local:sep(0)>>>" > /var/lib/check_mk_agent/spool/weather
echo "P Temperature count=$count;20;30 It is $count degrees outside" >> /var/lib/check_mk_agent/spool/weather
echo "<<<>>>" >> /var/lib/check_mk_agent/spool/weather
Karl
dabrain
(Andreas Breuer)
July 19, 2023, 9:37am
10
There might be an issue with the empty line, please get rid of this and also be aware there might be an issue with DOT’s in the output.
Output should look like this:
<<<local>>>
Issue with DOT in the output (?)
Check this Thread - Item not found in monitoring data even though it's there
@dabrain I removed the empty line, but it still not giving me any data on the temperature.
Also, if I put in a static number or read it from a file it is ok, even with a dot in it.
I will check the thread
I am fairly new to checkmk , Can you please explain to me how I go about using your modified script @kdeutsch ?
kdeutsch
(Karl Deutsch)
July 20, 2023, 6:28am
13
replace your script with mine in /usr/lib/check_mk_agent/local
. You should also change the first line to #!/bin/bash
Karl
Hi @kdeutsch ,
Sorry to say, but it did not work. Same result
Ronny
kdeutsch
(Karl Deutsch)
July 20, 2023, 10:30am
15
too bad - your script works fine for me. Let me know if you have found a solution.
Karl
I suspect something with permissions or network, so I will investigate further and update this thread.
Thank you for answering and helping me troubleshoot, @kdeutsch and @dabrain
Ronny
