Monitoring ceph clusters with 2.0
Hi, I’d like to monitor my ceph clusters with checkmk (latest version).
When I try to create a rule for ceph_status I get the following message at activation:
check_mk: Found configured rules of deprecated check group "ceph_status".
These rules are not used by any check.
Maybe this check group has been renamed during an update, in this case you will have to migrate your configuration to the new ruleset manually.
Please check out the release notes of the involved versions. You may use the page "Deprecated rules" in WATO to view your rules and move them to the new rulesets.
Questions:
  • are there any supported plugins for monitoring ceph clusters?
  • If there are, where can I find documentation about them?
  • Is there any manual how to do the mentioned manual migration? I have no clue what to do
Thnx in advance.
Update:
The waring is very misleading, there is not even a Deprecated Rulesets anywhere in Checkmk (see screenshot)
Bildschirmfoto von 2021-05-28 12-00-53
