I was install checkmk_1.6P17 and i’m trying to go and monitor cisco Switch,router,asa,etc… but i see that check_mk doesn’t extract cpu,ram,Hardware status and many others. currently these are controlled through nagios using the “check_nwc_health” plug-in.
currently the devices have been created in checkmk in standard mode so snmp has been activated. can you give me some advice on how to proceed?
is it possible to use the old “check_nwc_health” plug-in? or is there a better way?
I don’t know this plugin. But it should be possible: You have to copy the plugin to your site directory: local/lib/nagios/plugins. After that you configure the plugin via WATO → Host & Service Parameters → Active Checks → Classical active and passive monitoring checks.
Hello
if configured properly, Checkmk should find nearly everything on your Cisco device.
We monitor ~12000 Switches, APs and their Controllers with it.
i think what you are missing are the SNMP settings of your host
Check_nwc_health is a classical Nagios plugin. It works but it is not needed here.
We also have >100 Cisco Routers with no missing infos.
May you have some rules that disable this services.
Try to monitor just one device on a fresh test site.
But I don’t think this has anything to do with my problem.
The configuration is correct the snmp test was successful. surely there will be some settings in checkmk but I don’t know which one. what configuration have you set to checkmk?
I could use Bulk discovery but I should always run for each device the command check_mk --debug -v --checks cisco_fan -I SW-C2960-B otherwise I don’t see the fan service.
but this happens also with other active check.
for example if I wanted to add CPU service I would have to run check_mk --debug -v --checks cisco_cpu -I SW-C2960-B otherwise by default is not added.
Hi Dario,
normaly everything in CMK is Rule based. No need to do same doings again and again
There are many ways to classify devices so that the rules target as wished.
I am wondering a little bit why your cisco did not show all known services, for our cisco routers i get all infos without any additionally action, inclouding Fans and CPU
And… there is a little missleading point, that are not active checks
There is explained how snmp works with CMK and why in some cases CMK did not know that there is a cisco device to monitor. Maybe @andreas-doehler or @wittmannthom can help you in this cases.
