Does someone monitor GRE tunnels on their cisco switches ?
You can have a look at the Cisco checks of my colleague if there is something inside you need
Great repository.
Installed it. But where can I find the installed check in 2.0 ?
OMD[cmk]:~$ mkp list
cisco_vpn_tunnel
OMD[cmk]:~$ mkp show cisco_vpn_tunnel
Package file: /omd/sites/cmk/var/check_mk/packages/cisco_vpn_tunnel
Version: 20180806v.0.1g
Packaged on Checkmk Version: 1.4.0p35
Required Checkmk Version: 1.2.8b8
Valid until Checkmk version: No version limitation
Title: Monitor Cisco VPN Tunnel
Author: Th.L. (thl-cmk[at]outlook[dot]com)
Download-URL: https://thl-cmk.hopto.org
Files: checks(1) web(2)
Description:
Monitors Cisco VPN Tunnel. Complete rewrite of the original check.
Creates one service for each VPN Tunnel.
perfdata contains: IKE and IPSec statistics for uptime, in/out octets and packets.
@Alco what do want to monitor exactly? The Interface as such or somthing else? If you only want to monitor the interface i guess you need to change/create a interface discovery rule and add “131 - tunnel” to the discovered interface types.
One thing about the cisco_vpn_tunnel, this is still for pre CMK 2.0 versions and not yet testet with version 2.0.
Thanks, Yes I want to monitor the status if it is up or down
ext>sh ip int brief tunnel 1
Interface IP-Address OK? Method Status Protocol
Tunnel1 172.16.1.1 YES manual up up
Yes that was it, after enabling this rule all the interfaces became visible
