I try and get :
Error in agent based plugin cisco_wlc: name 'WlcClientsSection' is not defined
To be complete I give you the complete plugin that I put in /omd/sites/ensr/local/lib/python3/cmk/base/plugins/agent_based/ :
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# Copyright (C) 2019 tribe29 GmbH - License: GNU General Public License v2
# This file is part of Checkmk (https://checkmk.com). It is subject to the terms and
# conditions defined in the file COPYING, which is part of this source code package.
# Modifications for virtual C9800
# Should be put in :
# /omd/sites/ensr/local/lib/python3/cmk/base/plugins/agent_based
"""Cisco WLC sections and checks
>>> import re
>>> all(re.match(VERSION_CISCO_WLC_PATTERN, v) for v in (
... ".1.3.6.1.4.1.14179.1.1.4.3",
... ".1.3.6.1.4.1.9.1.1069",
... ".1.3.6.1.4.1.9.1.1615",
... ".1.3.6.1.4.1.9.1.1645",
... ".1.3.6.1.4.1.9.1.1631",
... ".1.3.6.1.4.1.9.1.1279",
... ".1.3.6.1.4.1.9.1.1293",
... ".1.3.6.1.4.1.9.1.2170",
... ".1.3.6.1.4.1.9.1.2171",
... ".1.3.6.1.4.1.9.1.2371",
... ".1.3.6.1.4.1.9.1.2250",
... ".1.3.6.1.4.1.9.1.2370", # Cisco Aironet 2800
... ".1.3.6.1.4.1.9.1.2391", # Cisco WLC C9800 CL
... ".1.3.6.1.4.1.9.1.2427",
... ".1.3.6.1.4.1.9.1.2530", # Cisco WLC 9800
True
>>> any(re.match(VERSION_CISCO_WLC_PATTERN, v) for v in (
... ".1.3.6.1.4.1.14179",
... ".1.3.6.1.4.1.9.1.1068",
... ".1 3.6.1.4.1.9.1.1069",
... "1.3.6.1.4.1.9.1.1069",
False
from typing import Any, Dict, List, Mapping, Optional
from .agent_based_api.v1 import (
SNMPTree,
register,
Service,
Result,
State as state,
matches,
from .agent_based_api.v1.type_defs import (
StringTable,
CheckResult,
DiscoveryResult,
Section = Dict[str, str]
OID_sysObjectID = ".1.3.6.1.2.1.1.2.0"
VERSION_CISCO_WLC_PATTERN = "|".join((
".1.3.6.1.4.1.9.1.2391", # Cisco WLC 9800 CL
".1.3.6.1.4.1.9.1.2489",
)).replace(".", r"\.")
map_states = {
"1": (state.OK, "online"),
"2": (state.CRIT, "critical"),
"3": (state.WARN, "warning"),
def parse_cisco_wlc(string_table: List[StringTable]) -> Section:
>>> parse_cisco_wlc([[['AP19', '1'], ['AP02', '1']]])
{'AP19': '1', 'AP02': '1'}
return dict(string_table[0]) # type: ignore[arg-type]
def discovery_cisco_wlc(section: Section) -> DiscoveryResult:
>>> list(discovery_cisco_wlc({'AP19': '1', 'AP02': '1'}))
[Service(item='AP19'), Service(item='AP02')]
yield from (Service(item=item) for item in section)
def _node_not_found(item: str, params: Mapping[str, Any]) -> Result:
infotext = "Accesspoint not found"
for ap_name, ap_state in params.get("ap_name", []):
if item.startswith(ap_name):
return Result(state=ap_state, summary=infotext)
return Result(state=state.CRIT, summary=infotext)
def _ap_info(node: Optional[str], wlc_status: str) -> Result:
status, state_readable = map_states.get(wlc_status, (state.UNKNOWN, "unknown[%s]" % wlc_status))
return Result(
state=status,
summary="Accesspoint: %s%s" % (state_readable,
(' (connected to %s)' % node) if node else ""),
def check_cisco_wlc(item: str, params: Mapping[str, Any], section: Section) -> CheckResult:
>>> list(check_cisco_wlc("AP19", {}, {'AP19': '1', 'AP02': '1'}))
[Result(state=<State.OK: 0>, summary='Accesspoint: online')]
>>> list(check_cisco_wlc("AP18", {}, {'AP19': '1', 'AP02': '1'}))
[Result(state=<State.CRIT: 2>, summary='Accesspoint not found')]
if item in section:
yield _ap_info(None, section[item])
else:
yield _node_not_found(item, params)
def cluster_check_cisco_wlc(
item: str,
section: Mapping[str, Section],
) -> CheckResult:
>>> list(cluster_check_cisco_wlc("AP19", {}, {"node1": {'AP19': '1', 'AP02': '1'}}))
[Result(state=<State.OK: 0>, summary='Accesspoint: online (connected to node1)')]
>>> list(cluster_check_cisco_wlc("AP18", {}, {"node1": {'AP19': '1', 'AP02': '1'}}))
for node, node_section in section.items():
if item in node_section:
yield _ap_info(node, node_section[item])
return
register.snmp_section(
name="cisco_wlc",
detect=matches(OID_sysObjectID, VERSION_CISCO_WLC_PATTERN),
parse_function=parse_cisco_wlc,
fetch=[
SNMPTree(base=".1.3.6.1.4.1.14179.2.2.1.1", oids=[
"3",
"6",
register.check_plugin(
name="cisco_wlc", # name taken from pre-1.7 plugin
service_name="AP %s",
discovery_function=discovery_cisco_wlc,
check_default_parameters={},
check_ruleset_name="cisco_wlc",
check_function=check_cisco_wlc,
cluster_check_function=cluster_check_cisco_wlc,
# C9800 Specifications
def parse_cisco_wlc_9800_clients(
string_table: List[StringTable],
) -> WlcClientsSection[ClientsTotal]:
section: WlcClientsSection[ClientsTotal] = WlcClientsSection()
for (ssid_name,), (num_clients_str,) in zip(string_table[0], string_table[1]):
num_clients = int(num_clients_str)
section.total_clients += num_clients
if ssid_name not in section.clients_per_ssid:
section.clients_per_ssid[ssid_name] = ClientsTotal(0)
section.clients_per_ssid[ssid_name].total += num_clients
return section
name="cisco_wlc_9800_clients",
parsed_section_name="wlc_clients",
detect=matches(OID_sysObjectID, r"^\.1\.3\.6\.1\.4\.1\.9\.1\.2530|2391"),
parse_function=parse_cisco_wlc_9800_clients,
fetch=[
SNMPTree(
base=".1.3.6.1.4.1.9.9.512.1.1.1.1",
oids=[
"4", # CISCO-LWAPP-WLAN-MIB::cLWlanSsid
SNMPTree(
base=".1.3.6.1.4.1.14179.2.1.1.1",
oids=[
"38", # AIRESPACE-WIRELESS-MIB::bsnDot11EssNumberOfMobileStations
Still got problems…
