SAMDAR
September 3, 2020, 10:09am
1
I would like to monitor a cluster with two nodes. On the cluster there are two sql instances.
node1
node2
Instance_sql3
Instance_sql4
I would like to assign different filesystems. for example
Instance_sql3 : Disk L - M
Instance_sql4 : Disk K - S
Someone is already struggling with this problem?. Is there a way to monitor as above? or ideas. through cluster services might be possible?.
thx.
Dario.
r.sander
(Robert Sander)
September 3, 2020, 11:18am
2
Create two cluster hosts with node1 and node2 as nodes.
Create two rules in “Clustered services for overlapping clusters” that map the services appropriately to the cluster hosts.
system
(system)
Closed
October 3, 2020, 9:18pm
3
