Monitoring Coverage Analyzer (MCA) – find what's running but not monitored
Hi everyone,
we’d like to introduce the Monitoring Coverage Analyzer (MCA), a free MKP (GPL v2) for Checkmk 2.5.0p15 and later. MCA looks at the agent data Checkmk already has, finds applications that are running on your hosts but not monitored yet (databases, web servers, Hyper-V, SAP, Veeam, Citrix, …), and tells you which agent plug-in or special agent would cover them. This includes not only the built-in checks, but also checks from the MKPs installed on your site.
Why this is helpful: in environments that have grown over the years, no one knows every server by heart, and monitoring gaps often only show up when something fails. MCA gives you an overview of the coverage across all hosts and sites, plus one service per host, so you can close these gaps step by step. MCA itself needs nothing on your hosts: it uses the agent data Checkmk has already cached instead of querying them again. It works in distributed setups; the analysis runs on the central site only, the remote sites just need the package.
Detection is based on a curated rules file, complemented by a fuzzy search across all check plug-ins available on your site. It is heuristic by design, so false positives and false negatives can’t be ruled out completely; findings you don’t care about can be ignored with a Setup rule.
The rules file is where we need you: please tell us about software MCA misses or reports wrongly, and suggest or contribute rules. You can attach an encrypted, pseudonymized support file (mcactl support-data) that only we can read.
Download: Releases · Gulaschcowboy/checkmk_monitoring_coverage_analyzer · GitHub
Details (installation, requirements, how it works): GitHub - Gulaschcowboy/checkmk_monitoring_coverage_analyzer: Checkmk extension (MKP) that finds running but unmonitored applications on agent-monitored hosts and suggests the plug-in that would cover them · GitHub
Checkmk Exchange
Feedback about false positives and false negatives, as well as pull requests, is very welcome. Please use the issue tracker on GitHub.
Developed with the help of AI coding assistants; designed, reviewed and
tested on real Checkmk sites by us.
Christian Wirtz (doctore74) & Alexander Wilms (gulaschcowboy)
Really liked the initiative, specially the coverage page that you showed.
I suggested something similar but on a role based approach.
Thanks Paulo, and thanks for the link! Your pinned comment describes
pretty much what MCA does today: it detects software from running
processes, systemd units and Windows services (plus agent sections and
installed packages), shows which plug-in or special agent would cover
it, and leaves the decision to the admin; anything you don’t need can
We deliberately stop at the suggestion, though. MCA’s detection is
heuristic, and a software that is briefly stopped or a host without
current agent data would change the result, so we don’t want it to
drive configuration (e.g. via automatically assigned labels) and
silently change plug-in deployment, thresholds or contacts. The admin
reviews the findings and configures monitoring deliberately.
The download is now also available on the Checkmk Exchange:
Hi everyone, I found and installed this tool. And I have to say, it’s one of the best extensions for Checkmk in at least five years.
It has really helped me identify things in my environment that aren’t configured optimally.
Best regards
