I installed the dell storage plugin: Checkmk Exchange
Api works via browser and postman but not via the plugin.
On the plugin I configured the url: https://IP/api/rest/, user name and password but I get the error: Exception: “403 Client Error: Forbidden for url” (https://IP/api/rest/ApiConnection/Login).
I can access the REST api with the user correctly, did I miss something?
That plugin is not for powerstores.
The conclusion I came to is the need to write a plugin or even just a local check in order to monitor the powerstore, as I don’t have any time for it we are simply relying on the powerstore emails.
If eventually you manage to monitor it using checkmk I would be greatful if you let me know.
