CMK version: 2.3.0.1
OS version: Ubuntu 22.04
Agent exited with code 1: HTTPConnectionPool(host='10.11.56.1', port=49000): Max retries exceeded with url: /upnp/control/WANIPConn1 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f4b89760230>, 'Connection to 10.11.56.1 timed out. (connect timeout=10)'))
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/util/connection.py", line 95, in create_connection
raise err
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
TimeoutError: timed out
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen
httplib_response = self._make_request(
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connectionpool.py", line 416, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connection.py", line 244, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/omd/sites/cmk/lib/python3.12/http/client.py", line 1336, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/omd/sites/cmk/lib/python3.12/http/client.py", line 1382, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/omd/sites/cmk/lib/python3.12/http/client.py", line 1331, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/omd/sites/cmk/lib/python3.12/http/client.py", line 1091, in _send_output
self.send(msg)
File "/omd/sites/cmk/lib/python3.12/http/client.py", line 1035, in send
self.connect()
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connection.py", line 205, in connect
conn = self._new_conn()
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connection.py", line 179, in _new_conn
raise ConnectTimeoutError(
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0x7f4b89760230>, 'Connection to 10.11.56.1 timed out. (connect timeout=10)')
File "/omd/sites/cmk/lib/python3.12/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/connectionpool.py", line 799, in urlopen
retries = retries.increment(
File "/omd/sites/cmk/lib/python3.12/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='10.11.56.1', port=49000): Max retries exceeded with url: /upnp/control/WANIPConn1 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f4b89760230>, 'Connection to 10.11.56.1 timed out. (connect timeout=10)'))
File "/omd/sites/cmk/share/check_mk/agents/special/agent_fritzbox", line 11, in <module>
sys.exit(main())
File "/omd/sites/cmk/lib/python3/cmk/special_agents/agent_fritzbox.py", line 205, in main
upnp_infos = list(_get_query_responses(connection, args.debug))
File "/omd/sites/cmk/lib/python3/cmk/special_agents/agent_fritzbox.py", line 186, in _get_query_responses
yield get_upnp_info(*query, connection)
File "/omd/sites/cmk/lib/python3/cmk/special_agents/agent_fritzbox.py", line 165, in get_upnp_info
response = _get_response(control, namespace, action, connection)
File "/omd/sites/cmk/lib/python3/cmk/special_agents/agent_fritzbox.py", line 147, in _get_response
response = connection.post(*post_args)
File "/omd/sites/cmk/lib/python3/cmk/special_agents/agent_fritzbox.py", line 129, in post
return self._session.post(
File "/omd/sites/cmk/lib/python3.12/site-packages/requests/sessions.py", line 637, in post
return self.request("POST", url, data=data, json=json, **kwargs)
File "/omd/sites/cmk/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/omd/sites/cmk/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/omd/sites/cmk/lib/python3.12/site-packages/requests/adapters.py", line 507, in send
raise ConnectTimeout(e, request=request)
requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='10.11.56.1', port=49000): Max retries exceeded with url: /upnp/control/WANIPConn1 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f4b89760230>, 'Connection to 10.11.56.1 timed out. (connect timeout=10)'))
Hey guys I’m trying to connect my fritzbox instance to CheckMK.
From what I saw it is trying to reach port 49000 which is not available on the device. (Since this device is managed by a 3rd party organisation). Is there a way to change the port to the correct http port and map it to the check?
Also when trying to accesss the /upnp/control/WANIPConn1 on the http port I’m still not seeing any information.
The CMK instance is running through a VPN and is trying to reach the routers, not sure if this is a going to be a problem, but I suspect if it’s hosted on a specific port.
Any ideas are appreciated.
