**CMK version:2.1.0p9.cee
**Error message:Status: Connection Error (Failed attempting to communicate with cluster collector at URL
We have followed the guide on the homepage and we can get most information from the cluster, the problem is that the service for cluster-collector fails with error message
Status: Connection Error (Failed attempting to communicate with cluster collector at URL.
We are using an ingress and the URL is the following http://10.0.139.128:8080.
Have we missed some step you need to do when using ingress instead of node port?
Is there any kubectl command we should run to get more info?
yes, I meant the installation via helm. I got a bit confused as some of the values (especially the service port) set via helm deviates from the manifests (8080 vs. 80) and I thought that was the issue at first.
Next I thought that something was wrong with the network policies, so I removed them but that did not help either.
Did you check if you get data with a debug pod as described here?
For me it looks like quite a lot of data is missing without the cluster-collector as the Kubernetes dashboard is pretty empty.
