When we try to monitor a kubernetes cluster running in Azure the agent returns a error message saying “Agent exited with code 1: Invalid value for names, must not be None”
Tried to debug but the output doesnt give me any suggestions what the problem can be.
Has anyone seen this error and if yes how did you solve it?
In total you have five times the images with the name = null.
We have also seen this problem before with Openshift and now it shows up with AKS. This message gets triggered from here:
/omd/sites//lib/python3.9/site-packages/kubernetes/client/models/v1_container_image.py
To get around with this problem, here is a temporary workaround:
Open this file and comment out line number 79 and 80. If needed, restart the site and reschedule.
That solved the problem for us, so thank you very much.
Is there permenant fix in the works for this or should we just note down the temporary workaround?
