Monitoring open shift in checkmk raw edition
Hello team,
Iam looking to monitor openshift cluster in a raw edition checkmk, I see there is some feasible solutions through checkmk docs Monitoring OpenShift
But here it explicitly says Monitoring OpenShift clusters is only possible with one of the Checkmk commercial editions, is it possible to monitor the openshift cluster in raw edition, let me know if there is anything that I can go through.
CMK version:
2.3.0p6
OS version:
Red Hat Enterprise Linux Server 9.2
Thanks,
Aru
Hello @Aru,
the Checkmk RAW Edition is the Open Source version of Checkmk and not one of the commercial editions (Checkmk Enterprise, Checkmk MSP, Checkmk Cloud) thus you are not able to monitor OpenShift with the RAW edition of Checkmk.
Docs:
Monitoring OpenShift clusters is only possible with one of the Checkmk commercial editions.
Best Regards
Norm
There is no explicit OpenShift support in the Checkmk Raw Edition. However, OpenShift is (more or less) an ordinary Kubernetes cluster, so the usual options to monitor Kubernetes clusters should be applicable, including
Thanks norm,
good to know.
Regards,
Aru
Hello Heavy,
Yah agree with the point what you mentioned here, options of monitoring kubernetes clusters as openshift has some leads,
Thanks for the reply
Aru
