Monitoring Openstack through checkmk
Hello community,
I see checkmk provides feasibility solution to monitor VMs, container, Vmware ESXI , Openshift but I do not see any related docs that gives flexibility in monitoring the Openstack environment so is there anything the we can expect from updated versions in future or is any solutions available for monitoring Openstack.
Any suggestions will be helpful
Thanks,
Aru
Short answer is that no this is not possible.
But you have some support for Prometheus if you can pull metrics that way, but it will not be easy to setup.
Hello Anders,
Good to know, thanks for your reply.
regards,
Aru
