I have Checkmk Raw Edition 2.3.0p11, I have to monitor an oracle DB I am following this URL Monitoring Oracle databases. But I still don’t understand. I don’t know if I have to create a user in the Linux O.S. someone could help me.
I have an oracle 19c single restart. Any help would be appreciated.
As the documentation-link describes, you do not need/require to create a user on the OS-level, but on the Database-server level.
I think that is where your confusion started/misinterpreted what is expected to be configured.
I am running but nothing is coming back. I created the user according to the page for both oracle and asm. I am running from root the command mk_oracle -t and nothing comes back.
[root@oraprepro7 plugins]# ./mk_oracle -t
<<<oracle_instance>>>
<<<oracle_processes>>>
<<<oracle_sessions>>>
<<<oracle_logswitches>>>
<<<oracle_jobs>>>
<<<oracle_rman>>>
<<<oracle_tablespaces>>>
<<<oracle_locks>>>
<<<oracle_asm_diskgroup>>>
I don't know what else could be wrong. I have the files
[root@oraprepro7 plugins]# ls -l
total 240
-rwxrwxr-x 1 root root 48592 jun 17 13:36 mk_logwatch_2.py
-rwxrwxr-x 1 root root 48293 jun 17 13:36 mk_logwatch.py
-rwxr-xr-x 1 oracle oinstall 138981 jun 17 12:42 mk_oracle
-rwxr-xr-x 1 root root 6413 jun 17 12:42 mk_oracle_crs
[root@oraprepro7 plugins]# cat /etc/check_mk/mk_oracle.cfg | grep -v '^#'
TNS_ADMIN='/u01/app/grid/product/19c/grid/network/admin'
DBUSER='MONITOR:LOQUESEA'
ASMUSER='MONITOR:loquesea:SYSASM'
SYNC_SECTIONS='instance processes sessions logswitches'
ASYNC_SECTIONS='jobs rman tablespaces locks'
SYNC_ASM_SECTIONS='instance'
ASYNC_ASM_SECTIONS='asm_diskgroup'
CACHE_MAXAGE=600
DEBUG=yes
LOG_FILE=/var/log/check_mk/mk_oracle.log
[root@oraprepro7 plugins]# ´´´
If you can help me on what I am doing wrong I would appreciate it.
Regards
[root@oraprepro7 plugins]# ./mk_oracle -l
Logging to file: /var/lib/check_mk_agent/log/mk_oracle.log
./mk_oracle: línea 565: perl: no se encontró la orden
<<<oracle_undostat>>>
<<<oracle_recovery_area>>>
<<<oracle_recovery_status>>>
<<<oracle_longactivesessions>>>
<<<oracle_dataguard_stats>>>
<<<oracle_performance>>>
<<<oracle_locks>>>
<<<oracle_systemparameter>>>
<<<oracle_rman>>>
<<<oracle_jobs>>>
<<<oracle_resumable>>>
<<<oracle_iostats>>>
[2] [+ASM] [set_ora_env] TNS_ADMIN/sqlnet.ora: /network/admin/sqlnet.ora
[2] [PREPRO7] [set_ora_env] TNS_ADMIN/sqlnet.ora: /network/admin/sqlnet.ora
[root@oraprepro7 plugins]#´´´
