Hello, is there a way how to monitor output of “docker logs CONTAINER” command.
I would like to parse the output for example for strings like error or similar. So far I did not find any straightforward solution.
Thanks for giving me hint for the right direction!
I was also looking for a solution.
I could not find a ready made rule for docker container but there are some other options you can try.
Install checkmk agent inside the container and configure the agent to read the e.g var/log/syslog (probably a ubuntu base image is required for that)
Create a .sh script with your docker log command, save it in local/bin on the checkmk server. Run it as alternative program instead of the agent access. That will require that you create a dummy host to assign this rule to.
Write a special agent which reads the docker log command. That would be the most flexible option but requires also the most work.
You can pipe the log output to a file on your docker host and read the logfile with the check mk logwatch rule from the docker host.
