Good afternoon,
I’ve just install checkmk and have configured it to monitor some servers in my lab. The basic server monitoring is working well.
I’ve followed the blog post on configuring it to monitor Proxmox VE servers but can’t get checkmk to discover anything about the PVE server. All I get is:
Version: 2.0.0p12, OS: linux, [special_proxmox_ve] Version: unknown, OS: unknown, execution time 3.6 sec | execution_time=3.560 user_time=0.110 system_time=0.020 children_user_time=0.400 children_system_time=0.050 cmk_time_agent=2.980 cmk_time_ds=0.010
When running from the command prompt, I can manually run the Proxmox VE agent and it returns what seems like valid information:
MD[Gareth]:~$ share/check_mk/agents/special/agent_proxmox_ve '-u' 'checkmk@pve' -'p' '<pve password>' '<pve fqdn>'
WARNING 2021-10-27 12:46:57 cmk.special_agents.utils.misc: Cache: could not find file - start a new one
<<<proxmox_ve_node_info:sep(0)>>>
{"lxc": ["107"], "proxmox_ve_version": {"release": "7.0", "repoid": "7aa7e488", "version": "7.0-13"}, "qemu": ["100", "101", "102", "103", "104", "105", "106"], "status": "online", "subscription": {"status": "NotFound"}}
<<<proxmox_ve_mem_usage:sep(0)>>>
{"max_mem": 12370526208, "mem": 10416164864}
<<<uptime>>>
22559
<<<<ns1>>>>
<<<proxmox_ve_vm_info:sep(0)>>>
{"name": "ns1", "node": "pve0", "status": "running", "type": "qemu", "vmid": "100"}
I can therefore assume that the configuration of Proxmox and my username/password in checkmk is good. However, that information does not appear in checkmk.
OMD[Gareth]:~$ cmk -D pve0 | head -n 20
pve0
Addresses: 172.27.1.20
Tags: [address_family:ip-v4-only], [agent:all-agents], [criticality:critical], [ip-v4:ip-v4], [networking:lan], [piggyback:auto-piggyback], [site:Gareth], [snmp_ds:no-snmp], [tcp:tcp]
Labels: [cmk/os_family:linux]
Parents: rt1
Host groups: check_mk
Contact groups: check-mk-notify, all
Agent mode: Normal Checkmk agent, all configured special agents
Type of agent:
TCP: 172.27.1.20:6556
Program: /omd/sites/Gareth/share/check_mk/agents/special/agent_proxmox_ve --pwstore=4@0@pve_gareth '-u' 'checkmk@pve' '-p' '********' 'pve0'
Process piggyback data from /omd/sites/Gareth/tmp/check_mk/piggyback/pve0
Services:
checktype item params
The only difference between the cmk version and my manual attempts at running the agent is that cmk is using the internal password vault. I’ve double checked that though.
I can see the request hitting Proxmox VE as it shows up in the logs every few seconds:
Oct 27 12:54:01 pve0 systemd[1]: pvesr.service: Consumed 1.140s CPU time.
Oct 27 12:54:34 pve0 systemd[1]: Started Checkmk agent (172.27.10.60:34590).
Oct 27 12:54:37 pve0 systemd[1]: check_mk@501-172.27.1.20:6556-172.27.10.60:34590.service: Succeeded.
Oct 27 12:54:37 pve0 systemd[1]: check_mk@501-172.27.1.20:6556-172.27.10.60:34590.service: Consumed 1.797s CPU time.
Can someone guide me on how to further investigate this issue please?
Thanks in advance,
Gareth
