how to monitor any host with SNMP Mibs?
i use this guide but not working on host.
anyone can help me?
You cant use the Event console unless you send SNMP traps.
Checkmk does not use MIBS at all.
Hi @Easlay
To expand a bit on @Anders’ answer:
Checkmk does not need the MIB for SNMP Monitoring. Read more about this here: Monitoring via SNMP - Monitoring of SNMP devices with Checkmk
There are also a number of good blog articles that might be helpful: Blog | SNMP Monitoring | Checkmk
So unless you want to process SNMP Traps, you’re looking in the wrong place (the Event Console).
Hope this helps.
Elias
Hi @elias.voelker
i try your guide, but doesn’t work. have you got anthore tips? or there is any pluguins for MIBs?
i search on exchange.checmk but i don’t find nothing. D:
