Hello Group,
Has anyone has an experience with monitoring HCI SolidFire cluster and nodes?
I have a SolidFire storage and compute nodes that I’m trying to monitor with no luck.
I was looking for a proper module/script to add to my CMK server via git but there is a missing details.
Hi @keren
I don’t have experience with this, I don’t have such hardware. If I had one - from the URLs you posted - I’d probably try the first one, either via MRPE, from a host that has access to it, or as “classic check”, enforced with a rule. In 2.x the rule is called “Integrate Nagios plugins” as far as I know.
The Checkmk plugin from the second URL, looks like it has been written for a version, older than 2.x,
so it may not work without further modification. The PNP4Nagios *.php files will probably
be useless for Checkmk 2.x since it doesn’t use PNP4Nagios anymore.
HTH,
Thomas
