I am working on migrating some old, mostly manual monitoring scripts to CMK and I got stuck trying to add a simple TCP connection or just some remote machine’s port availability monitoring.
Looking around the docs I think this is the closest to what I want
but this is, as far as I can tell, monitoring the monitored host’s own ports, basically the netstat command.
I know I could rewrite my bash script (it is pretty much just a grepped output of a netcat command like nc -vz 1.2.3.4 1234), but I was wondering if there is any native solution/service/plugin I could choose instead.
check_tcp would be a good fit here. You can use MRPE to run the TCP check from Host A towards Host B.
The TCP check on Host A will be executed by the Checkmk agent.
