I have to monitor one web page - Just simple - is it alive.
I tried Check HTTP service (deprecated) service and Check HTTP web service - but none is working…
Can I ask for info which check I should use and what to set ???
Thanks,
WebPage is on IIS
WebPage has certificate from internal PKI
Link to web page: https://10.10.40.212
Perhaps you can tell what is not “working” instead? Impossible for us to just gess.
Also you dont have to provide a link to an internal webpage, we will not be able to access it…
1.As Check HTTP service (deprecated)
Service Name = my www check
Address (name / IP or proxy) → 10.10.40.212
Advanced: Disable SSL/TLS host name extension support (SNI) checked
And I have result → CRITICAL - Socket timeout after 10 seconds
2.As Check HTTP web service
HTTP web service endpoints to monitor (required) → do not user prefix → Service Name = my check2
URL = https://10.10.40.212
The result is - error sending request for url (): error trying to connect: invalid peer certificate: UnknownIssuer CRIT
