r.sander
(Robert Sander)
May 25, 2020, 11:03am
1
A customers asks me to implement a Linux agent plugin and check for the Wireguard VPN software.
Before starting to code I wanted to ask the community of anybody already has done some work on this (basically interpreting the output of wg show all).
Is anybody else interested in such an extension?
I’ve done it as a local check at a previous employer, unfortunately it’s their intellectual property and I can’t say much else.
I did find the following, though, which may give you some food for thought:
moetiker
(Manuel Oetiker)
May 27, 2020, 7:07am
3
r.sander:
wg show all
yes, that would be nice to have…
r.sander
(Robert Sander)
June 3, 2020, 8:48am
4
There is a first draft of an agent plugin and a check plugin available at https://github.com/HeinleinSupport/check_mk_extensions/tree/master/wireguard
Currently the service checks never turn “not OK” as they only record performance metrics.
moetiker
(Manuel Oetiker)
June 26, 2020, 9:16am
5
Look good and works… cool thanks Robert
