Unfortunately my server is in a non-internet connected environment, so autorefresh isn’t going to work, but I will try the “undecided” workaround.
Any… theories on what’s wrong? I mean, those /proc/mounts settings should never have changed, it’s been set to nosuid,nodev since install. Is the check just bad? I can just disable it if it’s useless, is this something I should bug report?
