I initally installed checkmk and added a remote siter later. The first site is now the master and the web-ui interface used to access the first and second site. I am looking to move the web interface and master to a new remote location and keep the agent only on the first & second site.
Anyone has experience / input on this? This is docker installation running 2.4
It depends. Form monitoring point of view its transparent but e.g. if you limit IP on the agent or on the firewall you need to change.
I case of distributed monitoring you need to change IP in the setup of master if remote has changed,
