MQ queue monitoring
Hello All,
I am using CheckMK Raw Edition 2.1.0p9, I need to monitor the depth of the alert queues of an application called MQ.
I have seen some rules that mention MQ.
I want to know if the plugin called ibm_mq works for wintel servers and by means of a discovery it adds the alerts or the rules to be used.
Add the plugin in the path C:\ProgramData\checkmk\agent\plugins
I did a discovery but I don’t add anything.
Configure some IBM MQ rules as queue and do not recognize, they are left in Pend status.
The servers where you need to monitor queues are Windows.
Regards.
Victor
the IBM MQ agent plugin in only available for these OS (not Windows):
In general, you can find out information which agent is supported through the page of the integration:
Hi Elias,
Thank you very much for your answer.
Excuse me, could the monitoring be done for windows using the yaml file?
Regards.
Victor Pineda
Hi Victor,
I don’t know enough about that to speculate.
Sorry!
Hello Elias,
Thanks for your help.
Regards.
Victor H Pineda
