The Issue
I don’t have SQL monitoring data on the CheckMK services GUI or in the agent output (pasted below). But I seem to get an output when I run cscript mssql.vbs on the command-line (in the checkmk plugins directory on the Windows server where the agent and MSSQL are installed). I haven’t added it here already since it’s really long, but I can add it if needed.
I was wondering if there is a specific rule to enable to be able to see services or a way to confirm why they appear when running cscript MSSQL.vbs but not in the agent output or GUI.
Thanks!
CMK version:
2.2.0p12 raw
OS version:
Windows Server 2022
None on this server specifically, but some of our SQL servers (configured to use the default SYSTEM user) have this issue when launching the MSSQL.vbs script on command line with: cscript ./mssql.vbs
Connecting using provider msoledbsql; Connecting using provider sqloledb; Connecting using provider sqlncli11 ;; ERROR: Login failed for user ‘’.; Login failed for user ‘’.
Checkmk version 2.2.0p12
+ FETCHING DATA
Source: SourceInfo(hostname='(HOSTNAME_OF_Server)', ipaddress='(IP_Address)', ident='agent', fetcher_type=<FetcherType.TCP: 8>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f8a721b1650]
Read from cache: AgentFileCache((HOSTNAME_OF_Server), path_template=/omd/sites/labplas/tmp/check_mk/cache/{hostname}, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False , file_cache_mode=6)
Not using cache (Too old. Age is 18 sec, allowed is 0 sec)
Connecting via TCP to (IP_Address):6556 (180.0s timeout)
Reading data from agent
Closing TCP connection to (IP_Address):6556
Write data to cache file /omd/sites/labplas/tmp/check_mk/cache/(HOSTNAME_OF_Server)
Trying to acquire lock on /omd/sites/labplas/tmp/check_mk/cache/(HOSTNAME_OF_Server)
Got lock on /omd/sites/labplas/tmp/check_mk/cache/(HOSTNAME_OF_Server)
Releasing lock on /omd/sites/labplas/tmp/check_mk/cache/(HOSTNAME_OF_Server)
Released lock on /omd/sites/labplas/tmp/check_mk/cache/(HOSTNAME_OF_Server)
[cpu_tracking] Stop [7f8a721b1650 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.830000001937151))]
Source: SourceInfo(hostname='(HOSTNAME_OF_Server)', ipaddress='(IP_Address)', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f8a721b1490]
Read from cache: NoCache((HOSTNAME_OF_Server), path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for '(HOSTNAME_OF_Server)'. Skip processing.
No piggyback files for '(IP_Address)'. Skip processing.
[cpu_tracking] Stop [7f8a721b1490 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<wmi_cpuload:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<fileinfo:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_phydisk>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_if>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_processor>>> / Transition HostSectionParser -> HostSectionParser
<<<df:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<logwatch>>> / Transition HostSectionParser -> HostSectionParser
<<<checkmk_agent_plugins_win:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<dotnet_clrmemory:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<ps:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<services>>> / Transition HostSectionParser -> HostSectionParser
Transition HostSectionParser -> NOOPParser
Transition NOOPParser -> NOOPParser
<<<systemtime>>> / Transition NOOPParser -> HostSectionParser
HostKey(hostname='(HOSTNAME_OF_Server)', source_type=<SourceType.HOST: 1>) -> Add sections: ['check_mk', 'checkmk_agent_plugins_win', 'cmk_agent_ctl_status', 'df', 'dotnet_clrmemory', 'fileinfo', 'logwatch', 'mem', 'ps', 'services', 'systemtime', 'uptime', 'winperf_if', 'winperf_phydisk', 'winperf_processor', 'wmi_cpuload']
HostKey(hostname='(HOSTNAME_OF_Server)', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f8a721c9c50]
value store: synchronizing
Trying to acquire lock on /omd/sites/labplas/tmp/check_mk/counters/(HOSTNAME_OF_Server)
Got lock on /omd/sites/labplas/tmp/check_mk/counters/(HOSTNAME_OF_Server)
Releasing lock on /omd/sites/labplas/tmp/check_mk/counters/(HOSTNAME_OF_Server)
Released lock on /omd/sites/labplas/tmp/check_mk/counters/(HOSTNAME_OF_Server)
CPU utilization Total CPU: 2.30%
Check_MK Agent Version: 2.2.0p12, OS: windows, TLS is not activated on monitored host (see details)(!), Agent plugins: 0, Local checks: 0
Disk IO SUMMARY Read: 0.00 B/s, Write: 26.1 kB/s, Latency: 109 microseconds
Filesystem C:/ Used: 9.21% - 18.4 GiB of 199 GiB, trend per 1 day 0 hours: +5.28 GiB, trend per 1 day 0 hours: +2.64%, Time left until disk full: 34 days 7 hours
Interface 1 [Intel[R] 82574L Gigabit Network Connection], (Connected), Speed: 1 GBit/s, In: 5.36 kB/s (<0.01%), Out: 1.70 kB/s (<0.01%)
Memory and pagefile RAM: 20.64% - 2.48 GiB of 12.0 GiB, 15 min average: 20.08% (2.41 GiB), Commit charge: 16.48% - 2.37 GiB of 14.4 GiB, 15 min average: 16.06% (2.31 GiB)
Processor Queue 15 min load: 0.00, 15 min load per core: 0.00 (4 logical cores)
Service Summary Autostart services: 64, Stopped services: 2
System Time Offset: -555 milliseconds
Uptime Up since Feb 06 2024 13:42:13, Uptime: 1 hour 40 minutes
+ EXECUTING INVENTORY PLUGINS
allnet_ip_sensoric: skipped (no data)
aruba_wlc_aps: skipped (no data)
check_mk: ok
check_mk: skipped (no data)
checkmk_agent_plugins: ok
checkmk_agent_plugins: skipped (no data)
cisco_meraki_org_device_info: skipped (no data)
dell_hw_info: skipped (no data)
docker_node_info: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
azure_load_balancer: skipped (no data)
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
inventory_docker_container_node_name: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
enviromux_micro_information: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortinet_firewall_network_interfaces: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
ipmi_firmware: skipped (no data)
k8s_service_info: skipped (no data)
kube_cluster: skipped (no data)
kube_cronjob: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mobileiron_inventory: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
primekey: skipped (no data)
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_routes: skipped (no data)
statgrab_net: skipped (no data)
win_bios: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_reg_uninstall: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
k8s_pod_container: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_if: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
mem: ok
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
netapp_api_info: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
prtconf: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
snmp_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_os: skipped (no data)
win_system: skipped (no data)
winperf_if: ok
winperf_if: skipped (no data)
[cpu_tracking] Stop [7f8a721c9c50 - Snapshot(process=posix.times_result(user=0.020000000000000018, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
[agent] Success, [piggyback] Success (but no data found for this host), execution time 0.9 sec | execution_time=0.850 user_time=0.020 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.830
