Hello together,
I have a question regarding the installation of multiple Check_MK Agents on a same host.
Here is the situation based on my favored concept I thought through. Please let me just know if my concept is bad, if there are better ways to achieve what I want or when I’m just missing something.
Situation (my favored concept):
I have one single monitoring-server which serves two sites:
- Site test
- purpose: testing checkmk-configurations (rules, etc.), before manually applying the “needed
configurations” on the prod-site; can be a playground aswell when testing stuff - has got a site-specific Check_MK Agent, which is configured via AgentBakery
- uses the test-site as deployment-server for auto-updates
- Site prod
- config-state differs from test-site; everything here was beforhand configured and tested on test-site
- purpose: mirrors the “real and correct configuration”, sending various important alerts etc pp.
- uses the prod-site as deployment-server for auto-updates
- important: in order to correctly test every config-adjustments, both sites need to have the exact same hosts to be monitored
- because the agent from test-site and prod-site can differ, I need both agents to be installed on the monitored host accessed by different ports
As mentioned, both sites serve their own Check_MK Agent. Both agents, let’s call them test-agent and prod-agent, are configured via AgentBakery on their respective site. Because I think its needed that the two agents differ, I already configured the following rules to make them different:
- Rule TCP port for connection to Checkmk agent: test-agent is accessed by 6556, prod-agent is accessed by 6557
- Rule Installation paths for agent files (Linux, UNIX)
- Directory for configuration files: /etc/check_mk_test (for prod-agent its _prod)
- Base directory for plugins and local: /usr/lib/check_mk_agent_test (for prod-agent its _prod)
- Base directory for variable data (caches, state files): /var/lib/check_mk_agent_test (for prod-agent its _prod)
- Rule Name of agent packages (Linux, UNIX): check-mk-agent-test (for prod-agent its prod)*
So far so good - theoretically…
The Problem is that I can not install both agents at the same time.
When I install the prod-agent via dpkg -i when the test-agent is already installed,
then the agent-controller and deployed systemd units, which got installed by test-agent beforhand, gets uninstalled (orange box) and there is a problem with the super-server.cfg (red box) because it is already from the test-agent. Somehow they collide, interfere each other, even though I changed for example some paths in rules.
And when I try to uninstall an agent, it says that “/var/lib/cmk-agent” is not empty but I can not find a rule in AgentBakerey to change it to “/var/lib/cmk-agent-test” for example.
Any ideas? Is it not the “checkmk-way” / bad practice to have two Check_MK-Agents installed simultaneously to test stuff?
Is it a dpkg-issue and I should install the second agent with dpkg -i --force-overwrite agent.deb?
I am really looking forward for help! Thanks in advance.
Greetings,
Julien
