I have 3 separate web portal wherein one would input a username and password
It resides on one single server.
I have created 3 separate “Service Names” for “check_http” namely WEBPOS, ADMIN and REPORTS that corresponds to its respective login page.
It has also an OK status respectively. Please see the first figure.
Now, I read in one post here that having a page that make use of username and password will require the use of the plugin “check_form_submit” to monitor the 3 web pages.
As what I understand I will also need to create 3 separate rules for each webpage… I was able to create the FORM for “webpos”
I copied the first rule “WEBPOS” and named it to ADMIN but it says:
CRIT - Unable to open https://https://stage.mydomain.com/admin//: [Errno -3] Temporary failure in name resolution
Questions:
- To monitor the HTTPS status of Multiple URLs will require separate rules, right?
- To monitor the status of a page that shows a page that requires a username and password will require separate “check_form_submit” rules, right?
- Why is it the original “check_form_submit” rule is OK but the copied one is not?
Any help is appreciated.
Chris
