this check (MySQL connections) records the highest connection count, since the service started.
This might or might not be helpful sometimes, but fact is that the CRIT state will never go away unless one restarts the service or changes the crit limit.
Is there a way to reset the counter, so that I don’t need to restart the service to get rid of the CRIT?
Actually the server plugin does not store the highest connection count, but MySQL does.
The check you are referring to (mysql.connections) picks the following two values
Max_used_connections 1
max_connections 151
from the ouput of mysql ... -sN -e "show global status ; show global variables ;" and relates them to each other. In my case 1 of 151 is 0.66% and that’s what it shows. The WARN/CRIT levels default to 3 and 5.
Are you asking how to reset the counter in MySQL or which service are you talking about?
You may try mysqladmin flush-status to reset the counters, see the docs.
By the way: I think it would be better, if the check would be WARN, if it happened in the past and only CRIT, if the max value is exceeded right now.
(if not by default, then at least as a possibility to configure it that way)
