Hi
I wish to monitor mysql .
i am following the below URL document.
just wish to know , is this a only way ? or any other alternate way check_mk provides ?
will this way create any impact on mysql performance ?
Hi
Hi.
This is the official way to monitor mysql Databases. If you want a differnt way, you will beable to write your own checks.
Rg,
Christian
Hi Cristian Thanks for the reply.
i m just trying to follow the default way .
but one small query as shown in below screen shot.
When i type MYsql in main search , i can see below 2 main Menus which allows to configure the mysql related settings . currently i m configuring in Service Monitoring Rules.but just curious to know what is Enforced services is option is used for ?
Auto-discovered checks, according to rule-sets vs. enforced checks no matter if they are found.
Only use enforced checks if you have a very special requirement.
But that’s not specific to MySQL checks, see the docs:
Thank you Martin for the reply.
