I have an error when displaying Nagvis to the sidebar. It is a quite long error message:
Failed to parse JSON request: 'Error (Error): Class "PDO" not foundarray(1) { [0]=> array(2) { ["function"]=> string(15) "nagvisException" ["args"]=> array(1) { [0]=> object(Error)#14 (7) { ["message":protected]=> string(21) "Class "PDO" not found" ["string":"Error":private]=> string(0) "" ["code":protected]=> int(0) ["file":protected]=> string(86) "/opt/omd/versions/2.2.0.cre/share/nagvis/htdocs/server/core/classes/CorePDOHandler.php" ["line":protected]=> int(279) ["trace":"Error":private]=> array(4) { [0]=> array(5) { ["file"]=> string(86) "/opt/omd/versions/2.2.0.cre/share/nagvis/htdocs/server/core/classes/CoreAuthModPDO.php" ["line"]=> int(57) ["function"]=> string(4) "open" ["class"]=> string(14) "CorePDOHandler" ["type"]=> string(2) "->" } [1]=> array(5) { ["file"]=> string(87) "/opt/omd/versions/2.2.0.cre/share/nagvis/htdocs/server/core/classes/CoreAuthHandler.php" ["line"]=> int(47) ["function"]=> string(11) "__construct" ["class"]=> string(14) "CoreAuthModPDO" ["type"]=> string(2) "->" } [2]=> array(5) { ["file"]=> string(79) "/opt/omd/versions/2.2.0.cre/share/nagvis/htdocs/server/core/functions/index.php" ["line"]=> int(44) ["function"]=> string(11) "__construct" ["class"]=> string(15) "CoreAuthHandler" ["type"]=> string(2) "->" } [3]=> array(4) { ["file"]=> string(76) "/opt/omd/versions/2.2.0.cre/share/nagvis/htdocs/server/core/ajax_handler.php" ["line"]=> int(59) ["args"]=> array(1) { [0]=> string(79) "/opt/omd/versions/2.2.0.cre/share/nagvis/htdocs/server/core/functions/index.php" } ["function"]=> string(7) "require" } } ["previous":"Error":private]=> NULL } } } } ': Expecting value: line 1 column 1 (char 0)
Does anyone have this error too? Or knows how to solve it?
Thanks in advance
