Thanks Yggy !
Like CLiX said, I try to add the command āchild-src *.mydomain.comā at the end of the āHeader always set Content-Security-Policyā but I canāt restart omd service after that.
File : /opt/omd/sites/āOMD-SITEā/etc/apache/conf.d/security.conf
I disabled all Header in this file and its seems to worked (half)
I try know to understand how this file works but Iām little confused, I disabled the old line 'Header always set Content-Securit-Policy" and created a new one :
Old :
Header always set Content-Security-Policy "default-src 'self' 'unsafe-inline' 'unsafe-eval' ssh: rdp:; img-src 'self' data: https://*.tile.openstreetmap.org/ ; connect-src 'self' https://crash.checkmk.com/ https://license.checkmk.com/api/verify; frame-ancestors 'self' ; base-uri 'self'; form-action 'self' javascript: 'unsafe-inline'; object-src 'self'; worker-src 'self' blob:" "expr=%{REQUEST_STATUS} != 200"
New :
Header always set Content-Security-Policy "default-src 'self' 'unsafe-inline' 'unsafe-eval' ssh: rdp:; img-src 'self' data: https://*.tile.openstreetmap.org/ ; connect-src 'self' https://crash.checkmk.com/ https://license.checkmk.com/api/verify; frame-ancestors 'self' ; base-uri 'self'; form-action 'self' javascript: 'unsafe-inline'; object-src 'self'; worker-src 'self' blob:; frame-src 'self' 'unsafe-inline' 'unsafe-eval' *."MYDOMAIN".local"
I had to delete "expr=%{REQUEST_STATUS} != 200"
and add frame-src 'self' 'unsafe-inline' 'unsafe-eval' *."MYDOMAIN".local"
Now the iFrame is displaying on the nagvis but the autologin doensāt work and when I type the login/password, Iām completly redirect on the iFrameās URL instead of displaying the URL in the iFrame of nagvis
Here is the link I use with iFrame :
https://HOSTNAME.domain.local/"OMD-SITE"/check_mk/login.py?_origtarget=/"OMD-SITE"/nagvis/frontend/nagvis-js/index.php?mod=Map%26act=view%26show=Overview&_username=monitoring&_password=monitoring&_login=1
Iāve this error on Chrome :
login.py?_origtarget=%2F"OMD-SITE"%2Fnagvis%2Ffrontend%2Fnagvis-js%2Findex.php%3Fmod%3DMap%26act%3Dview%26show%3DOverview:6
Unsafe attempt to initiate navigation for frame with origin 'http://"LOCALHOST" from frame with URL 'https://"REMOTEHOST"."MYDOMAIN".local/"OMD-SITE"/check_mk/login.py?_origtarget=%2F"OMD-SITE"%2Fnagvis%2Ffrontend%2Fnagvis-js%2Findex.php%3Fmod%3DMap%26act%3Dview%26show%3DOverview'. The frame attempting navigation is targeting its top-level window, but is neither same-origin with its target nor has it received a user gesture. See https://www.chromestatus.com/feature/5851021045661696.
(anonymous) @ login.py?_origtarget=%2F"OMD-SITE"%2Fnagvis%2Ffrontend%2Fnagvis-js%2Findex.php%3Fmod%3DMap%26act%3Dview%26show%3DOverview:6
Uncaught DOMException: Failed to set the 'href' property on 'Location': The current window does not have permission to navigate the target frame to 'https://"REMOTEHOST"."MYDOMAIN".local/"OMD-SITE"/check_mk/login.py?_origtarget=%2F"OMD-SITE"ā¦rontend%2Fnagvis-js%2Findex.php%3Fmod%3DMap%26act%3Dview%26show%3DOverview'.
at https://"REMOTEHOST"."MYDOMAIN".local/"OMD-SITE"/check_mk/login.py?_origtarget=%2F"OMD-SITE"ā¦nd%2Fnagvis-js%2Findex.php%3Fmod%3DMap%26act%3Dview%26show%3DOverview:6:30
(anonymous) @ login.py?_origtargetā¦26show%3DOverview:6
Someone have a clue on this ?
Best Regards,
